Wingwong
- Mar 20, 2018
Now check out the before and after of removing the lower Panel
Sooo Much Rooom!!!
Exhaust,oil tank, drain plug, chain tensioner, chaincase, are all easily accessible now.
I suggest sticking with OEM TORQUE SPECS
Once everything is torqued To spec it’s time to add the oil.
Note: add oil in oil tank, and follow instructions in owners manual. Oil change is now complete
Sooo Much Rooom!!!
Wingwong
- Mar 20, 2018
Welcome!!
Lots of great reading on here to help with your decisions
Thanks Kevin, any recommendations whether or not I should stud my track?
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Do you have any pics of the rivnuts that you installed? I've heard them referenced before and if like to see how they work.
My feelings on studs- if you don't put them in, you can't put one through your heat exchanger... call me paranoid!
Wingwong
- Mar 20, 2018
Hi Kkutz,
Good point on studs. :/
I’m been hesitating between aluminum and SS, so... I picked up both!
I purchased a kit which came with the following sizes:
M4,M5,M6,M8 aluminum
Also bought:
10-24 SS
1/4-20 SS
Im gonna size them up and test the rivnuts on some scraps before touching the sled.
Hopefully this weekend I’ll have it complete and pictures up and if I screw up, it’s gonna be posted too. :0
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
JUst did the lower panel on mine before putting it away, went with M-5's. Make sure whatever screws you use aren't too long where they are by the lower oil lines.
cobrajet ltx dx
- Oct 5, 2014
- pa
- 2015 yamaha ltx dx
Here are my first items installed ( done by dealer for delivery)
View attachment 139755 View attachment 139754 View attachment 139752 View attachment 139753
Add a 6 position racewerx coupler block in the rear,every procross should have one.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Good idea on the rivnuts, coming from a boosted apex, you need access to chain case often. This much power really stretches the chains out. I burned through one chain a year or every other year. I checked chain tension once at the start of the year and then before any trip. Its helpful to know how much you keep tightening it as you know the chain is stretching and once you do it enough you can tell if you need to replace the chain without opening the case. I'm going to tune mine with a small muffler as well so I can reach the adjuster without removing much. Apex chain case was bullet proof with proper maint, need to develop some confidence in the new one now.
Wingwong
- Mar 20, 2018
Perf
Perfect thanks
Perfect thanks
Wingwong
- Mar 20, 2018
Thanks for the suggestion didn’t think the chain would stretch so much, I will keep an eye on it
Wingwong
- Mar 20, 2018
I have been looking into to the racewerx coupler.
Yamaha has one but not sure of quality
cobrajet ltx dx
- Oct 5, 2014
- pa
Quality is excellent (racewerx).I have been looking into to the racewerx coupler.
Hit up Travis at BOP, he has one for sale.
You’ll never use the factory setup again once you install one and see how that procross responds to the positions.
Wingwong
- Mar 20, 2018
Ok, completed the “rivnut challenge”. It went alright once I had the right tools for the job. Watch my video to see what Rivnut tool to buy
Wingwong
- Mar 20, 2018
TOOLS AQUIRED:
I picked up a few different sizes of rivnuts. In the end I went with aluminum M6 all around except for one. The rivnut to the left of shock tower is SS M6.
Turned out well. Will change bolts soon, just used SS for now.
- 227K
