vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
2015 rtx-le sr viper 129" track
2010 rs ltx gt vector
Track is equal distance at the back wheels .Drivers not aligned?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
how many studs?
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
I believe it's 144 , 4 studs then 2 studs, and so on
New slides? You sure you have chain adjusted properly? Maybe try making a video with phone.Do not hear it on the stand , heard when I back the sled out of the trailer yesterday .,
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
Slides look fine , dealer did chaincase oil and assume he adjusted correctly he's been with yamaha for close to 20 years , I give him a 9.75 out of 10 , doesn't do it on stand only on ground , no snow here to make a videoNew slides? You sure you have chain adjusted properly? Maybe try making a video with phone.
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
I'm at 942 miles started doing it after 200 miles noticed it took to dealer he went over it top to bottom he thinks it's the track itself , if I could get a 1.35 or 1.5 is storm I would change from 1 in , Hurricane Dave thinks I should stay with it but put longer studs after his bundle tune goes on when I receive it hopefully Monday
STAIN
- Feb 29, 2004
- Vermont
- Vermont
you may be hearing the studs going over the drivers.....I believe it's 144 , 4 studs then 2 studs, and so on
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
Anything a possibility ,just never heard this on my vector , supercharged apex or viper or pro s
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
think I found the strange nnoise coming from rotor going into the plastic piece on bottom side picture won't upload says it to large
RobX-1
- Coldwater, OH
Use Windows Snipping Tool to snip an image of your original photo and then post the snipped image as it will be smaller in size.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Photo & Picture Resizer - Apps on Google Play
Batch Photo Resizer ● Resolution Changer ● File Size Reducer ● Photo Size Editor
I use this app some else suggested here resize to 50% and good to post
RobX-1
- Coldwater, OH
Good point as OP may use an Android device vs. a Windows PC.
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Your driveshaft/bearing is goneThink I got it
That is your rotor digging into protector?
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
That's pretty bad not at 940 miles
- 6K
