vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
2015 rtx-le sr viper 129" track
2010 rs ltx gt vector
When I broke the secondary bolt all pieces went flying,there were small washers behind the collar some where (front or behind ). It's listed as collar 2 in parts book 8kc-ra447-00-00 in the diagram , mine has 3 , not sure we're they go , what does it change by moving locationNot having a good night finish up hurricane flash , changed the secondary spring when I put the main bolt back on it broke , luckily I was able to drill it out , need new bolt, thought tge torque was 65 , apparently not or my torque wrench is no good
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Those are for belt deflection.
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
Ok , thanks for your help
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
Well turns out not track or noise from bearing , new rotor protector came in , definitely old one is flatten out , likely from sled lift . Glad I did the hurricane tune myself , or this annoying noise might not of been solved
- 7K
