theewarrior
Who has the newest version of the 270 race with the standalone boost in the dash cluster ? If so what are you run showing for boost ?
@123
where did you bought it ? part number? thksThe only better than stock spring I have never blown a belt with is the cat red/white. This spring will stay in my sled. Works flawlessly. Gates carbon too.
@123
thks0648-114
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Update: I blew two belts last season an oem and a gates with the red/white. So like others I'm hoping the offset and other small improvements will help for this season.
Red/white still my fav spring though.
@123
did you try dalton B/O?Update: I blew two belts last season an oem and a gates with the red/white. So like others I'm hoping the offset and other small improvements will help for this season.
theewarrior
This red/white spring is this driven or secondary some seem to be talking about both
krm
- Apr 22, 2016
- ny
Driven and secondary is the same clutch .Do you mean Drive ??This red/white spring is this driven or secondary some seem to be talking about both
theewarrior
Sorry yaDriven and secondary is the same clutch .Do you mean Drive ??
theewarrior
What degree setting are people useing this Spring on?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
What small improvements is that? Hope you're not believing the new SRX clutching is going to help your belt problems, cause if you are, you're going to be very sad/mad.
We had best hope the offset cures the problem.
I'll be gearing back down to stock along with a fan blowing on the clutch's and belt as well as using Hurricane's alignment tool.
theewarrior
Hi there just wondering what clutching you are using
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Yes These are the improvements I'm hoping for as well except for the fan. Just adding fresh air cooling. And yeah the srx clutching to me was a big disappointment.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I just slapped my 21 tooth back in today, also going to re-seal my oil tank. Surprised to see how much my chain stretched in short period of time. 270hp sure is hard on chain.
Wondering what guys are thinking for clutching this season....
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I agree why is the chain stretching so much? Aren't hyvo chains not supposed to stretch?
