DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I don't believe these relays are the same as the apex/nytro relays.Part number for this red solid relays?
Sent from my iPhone using Tapatalk Pro
Correct. No solid state relays exist for this issue in ProCross chassis.Will put it in FAQ though.I don't believe these relays are the same as the apex/nytro relays.
Done. Under problems and fixes in FAQ
Its in faq. Multiple threads going on it.I could add this to the FAQ, so guys know to just pill the relay and warm them up.
YukonMP
- Dec 25, 2014
- Yukon Territory
Might be worthwhile carrying a couple hand warmer pouches and an elastic band or two. Won't need electricity for the blow dryer and don't even have to pull the thing in and out.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Hey Dan..... now that you have a sled,could you take a picture of the relay in question?Ok great FYI as it may be a cold winter finally...
But guys, come on.. A pic is worth a thousand words in this case, post it please, circle the relay so we all know which one to take into the hotel!
Great work here
Dan
Should be merged into one thread.
I did.Should be merged into one thread.
fourload
I can't believe I have to go through this crap again. I have had many Apex, Vector and Nytro cold start problems until I replaced with the solid state relays. Someone needs to come up with a fix asap.Correct. No solid state relays exist for this issue in ProCross chassis.Will put it in FAQ though.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
This is my third Yamaha and I only had a relay freeze up once. That was on my wife's Nytro. Very easy to pull the relay and warm it up. I don't know what the big fuss is about. I was up in Hearst Ontario with my Nytro and Apex and on a -30 morning the only sleds that wouldn't start were a Polaris 600 Dragon and a Doo 600 SDI.
DMCTurbo
- Nov 12, 2005
It's really simple, take your hood off and open the fuse box. You'll see the relays, if you pull them out it says what they control under neath. It's not 1 relay per say that may give you trouble, it could be any of them. It's really worth guys having a look at these so your familiar with the location so when it's 30 below you know right where to go. Last year I just brought them all inside, if I remember correctly they are all identical. I'll take a picture shortly.Hey Dan..... now that you have a sled,could you take a picture of the relay in question?
DMCTurbo
- Nov 12, 2005
OK so I lied, there are 2 types of relays, the 4 small ones are all identical and the 2 large ones are identical. Notice once the relays are removed you can see what they control. Also tucked up under the fuse box cover Yamaha has included spare fuses.
Guys it’s a simple fix for us but think of those that don’t know or your girls. Heck one of mine I won’t even show her how to change a tire or add oil in car. It would be bad guaranteed. There is known solution but will not happen with cat wiring the way it is.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Very nice...someone should simply sticky THAT IMAGE showing the SMALL CORNER RELAY being the fuel pump.OK so I lied, there are 2 types of relays, the 4 small ones are all identical and the 2 large ones are identical. Notice once the relays are removed you can see what they control. Also tucked up under the fuse box cover Yamaha has included spare fuses. View attachment 134603 View attachment 134604 View attachment 134605
DONE
Very nice work my friend!
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Cannondale...
I made up a nice simple self explanatory image so guys can just keep this image on their phones to remember when their sled wont start.
Can you STICKY this image for us?
thanks to DMCTurbo!
Dan
thanks to DMCTurbo!
Dan
