1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
You could use the Yamaha Secondary but like yamamarc indicated not without modifications. I am pretty sure KnappAttack experimented with a Team Primary and wide belt off a Tcat and a Yamaha secondary with mods a few years back.
This guy has a xs 825 belt on it.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
It doesn't look like you can adjust the primary to the smaller belt width on that primary?This guy has a xs 825 belt on it.
To make it work they must have disassembled the primary and machined the spider ect for narrower belt?
Maybe he is just running the primary with the excessive belt side clearance?It doesn't look like you can adjust the primary to the smaller belt width on that primary?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Must be!!Maybe he is just running the primary with the excessive belt side clearance?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I dont know how he is using the narrower belt.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Thats a defective cover or the bolts were over torqued IMO. Did you blow a belt at wfo by chance? Wondering if maybe when the clutch halves slapped together it stressed the cover?Yes. The cover is broken around the bolt on both bolts shown. It should have a shoulder that goes over the top of the tower where its notched
Turboflash
- Mar 18, 2019
- Southern MN
Were the bolts loose?
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Sorry to see the damaged clutch. I doubt any stock clutch can take big tunes and big speed for too long. I know most people are not made of cubic dollars but it has been my experience that a drivetrain designed for XX HP may not hold up when you put XXX HP against it. I first learned this as a kid when we put a 327 in a Chevy Vega. The rear end lasted one weekend LOL. Not sure what the new cat clutch is designed to live with when big power is applied.
On early Tcats we twisted the jack shafts when adding HP and hooked them hard on the ice. We ended up having better shafts built by a tool company. My point is that we need to invest in the drivetrain when we add big HP. I bit the bullet on TAPP on my 1100 a couple of years ago and have been happy with it. High power will always try and find the next weak link in the drive train be it clutches, belts, shafts, gears, etc.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Why not mod the secondary to accept the wider belt? Or could you run a team tss o4?
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
When I install a cover I wind 3 bolts in(every other hole), trying the keep the cover as straight as possible. Once I get the cover mated to the towers, I wind the other 3 bolts in and torque all 6 bolts by hand afterward. The weird thing is I had just made a pull, turned around and started back up the trail, got to about 25-30mph and heard a grinding noise like the top gear popped out. I grabbed the brake to keep it from turning then hit the throttle once the noise stopped and the belt grenaded into 1000 piecesThats a defective cover or the bolts were over torqued IMO. Did you blow a belt at wfo by chance? Wondering if maybe when the clutch halves slapped together it stressed the cover?
justinator
- Mar 25, 2007
- Maine
10-4, just curious because typically cover bolts are around 96inch lbs or so.........not very tight really. Wouldnt take much to overtorque them but just as well could be a defective cover. Not sure about the grinding noise but safe to say it was belt related if it blew apart seconds later lolWhen I install a cover I wind 3 bolts in(every other hole), trying the keep the cover as straight as possible. Once I get the cover mated to the towers, I wind the other 3 bolts in and torque all 6 bolts by hand afterward. The weird thing is I had just made a pull, turned around and started back up the trail, got to about 25-30mph and heard a grinding noise like the top gear popped out. I grabbed the brake to keep it from turning then hit the throttle once the noise stopped and the belt grenaded into 1000 pieces
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Stock cover bolts are very torque sensitive. 911 cover included. I still go back to the video when the guy mentions how light and small the cover is on that clutch. Betting the power of a tuned sled could be a factor for the “lightweight” cover on this clutch
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
No question. I threw a belt on and rode it home with no noises or problems but it makes me curious as to what happened first.... did it blow a belt and that caused the shoulder to break, or did the shoulder break and go through the clutch and ruin the belt?10-4, just curious because typically cover bolts are around 96inch lbs or so.........not very tight really. Wouldnt take much to overtorque them but just as well could be a defective cover. Not sure about the grinding noise but safe to say it was belt related if it blew apart seconds later lol
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
My guess is the last option of the twoNo question. I threw a belt on and rode it home with no noises or problems but it makes me curious as to what happened first.... did it blow a belt and that caused the shoulder to break, or did the shoulder break and go through the clutch and ruin the belt?
- 54K
