That is from Airbox divider vibrating like a reed in a Duck call. Mine cracked on a wear point.
stingray719
I just pull the airbox out , opened it and the side where the divider is has a white chalky residue on it (on left side where the plastic is supposed to be bent looking at the sled from the front) is that normal?
Post a pic please. Not sure if you mean the horizontal divider or the air temp sender divider.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I should have taken a pic I put it back together sorry!Post a pic please. Not sure if you mean the horizontal divider or the air temp sender divider.
I cleaned the white residue off! Standing infront of the machine it was at the back right corner of the airbox where you heat and bend the plastic when modding(right side of bent plastic). It kinda look like water and oil mixed then dryed if that makes sense
http://www.ty4stroke.com/threads/airbox-mod-warning.133316/#post-1199325
Did it look like this?
stingray719
You tipped it up or over on its left side at some point? Sounds like what you said water and oil mix.
stingray719
The warning is nice but his box was not modified before now.
I know. Modding makes it worse. The bending of the support specifically.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
yes it did look like that! I did see any cracking thought
Yup that's residue from wear of plastic. Was waiting for more guys to see that.yes it did look like that! I did see any cracking thought
gpxsrx
- Dec 15, 2009
- way to many 2 strokes
I noticed mine has residue and it is also cracked, and it was never touched, Until I took it apart this weekend and did what I thought need to be done for the air box mod. mine is a 2015 rtx with just over 1000 milesYup that's residue from wear of plastic. Was waiting for more guys to see that.
I removed that divider in pic on advice of Excell who said they saw no difference with or without it. Has bothered me since. May try some glue to permanently put that in there.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
what about riveting a piece of aluminum to stiffen it up??I removed that divider in pic on advice of Excell who said they saw no difference with or without it. Has bothered me since. May try some glue to permanently put that in there.
I don't want to chance any metal getting sucked in motor. May just leave it out since cant tell the difference. Hate experimenting in there. Is pain to work on and could cost a motor.what about riveting a piece of aluminum to stiffen it up??
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
good point if and when mine cracks I will pull it out permanentlyI don't want to chance any metal getting sucked in motor. May just leave it out since cant tell the difference. Hate experimenting in there. Is pain to work on and could cost a motor.
Darren Johnson
- Nov 7, 2015
- Hillsdale
- 2014 Yamaha SR Viper
Ive seen a number of guys cut out the bottom of the box. i was wondering if this intake kit would be any different as it looks like it uses a different approach than the original intake hole in the box?
I just saw this on ebay and the question came to mind.
- Status
