yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This info should be posted across the forum..
I've had yamaha 4 stokes since 2011 and this is the first I hear ....
Thanks for the heads up
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I believe it is only a problem on the 3 cylinder nytro,SW vector,well venture,i guess any 1049cc 3 cylinder motor.This info should be posted across the forum..
Thanks for the heads up![]()
Dano74
- Nov 16, 2014
- 2008 Yamaha nytro rtx
When changing weights in mine I've noticed it will start hard after rotating the clutch...thankfully I rotate ccw whenever I've done it, but afterwards I give it a little bit a throttle to get it to fire or it will crank and crank.
SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
how you suppose to change a belt?...dont u have to roll it back to get the belt offMan that last vid. you had made when the lg ball of snow fell into your lap,what had that done to your sled that day?
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
no.how you suppose to change a belt?...dont u have to roll it back to get the belt off
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Aaron Excell told me NEVER rotate it backwards when they went over the sled at pickup. Good dealer. Covered everything from reverse actuator to that...too bad I can't remember it all....lol!
Hereshowe
- Mar 20, 2021
- Sidewinder
Ok, I know thus is an old conversation, however, I believe I spun my clutch backwards by hand a few turns.
I have yet tried to start it thou as I have a couple sd codes that popped up prior to spinning clutch.
Codes 12,39 and 46 and a bad smell from engine (smelt like hot brake pads , but that wasn’t the case)
Anyways, is there a way ensuring chain is in correct orientation without taking it apart?
Also, any insight on what caused these codes.
The only things that were different lately.... I installed a Yamaha quick connect visor plug and USB plug in for the 12v socket that I use for my iPhone. At that time , my phone was actually not plugged into.
I also notice that I loose my hot grips when I use electric visor.
Thanks for support .... ‘17 sidewinder ltx se 14000km
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Did you start it?
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Sounds like you have a couple different things going on here. I am sure someone here will know what the codes are? As far as the timing chain sled would not run very good if you jumped a tooth. And if jumped more than a tooth you will know it won’t be good. You would have to remove gas tank and valve cover to check for sure, then if chain has jumped it is a bit more work to correct as you have to tilt motor forward to get at tensioner.Ok, I know thus is an old conversation, however, I believe I spun my clutch backwards by hand a few turns.
The only things that were different lately.... I installed a Yamaha quick connect visor plug and USB plug in for the 12v socket that I use for my iPhone. At that time , my phone was actually plugged into.
Hereshowe
- Mar 20, 2021
- Sidewinder
I have not tried to start yet.Did you start it?
Will we have the same problem on the newer Apex or Vectors 1049
Hereshowe
- Mar 20, 2021
- Sidewinder
I know what codes are but what caused them all to come at one time. Did one trigger it and snowballed a couple extra codes.
12- crank sensor
39 - abnormal FI
46- abnormal power supply.
I am thinking a melted wire somewhere (may explain the smell).
Bad stator?
Or did one of my new accessories wires fail.
Or a loose ground wire?
Which fuse or relay should I be looking at?
Not sure how to test a relay thou.
90% of time it’s what you did last. Go back to the accessories and remove them then see what happens.
Hereshowe
- Mar 20, 2021
- Sidewinder
Can I spin clutch by hand and be able to tell if timing is so far out that it will jam and make a mess of things if started?
Sure. Pull the plugs out and turn it over by hand. Should feel if valves hit. I highly doubt you jumped time but best to be sure.Can I spin clutch by hand and be able to tell if timing is so far out that it will jam and make a mess of things if started?
- 23K
