pro116
Don,the race is being held at Martin,MI.Jamie Bellman will be putting it on there all ready have an aspahlt and grass drag race there now the amsnow shoot out so it should be a huge event 3 races at one plce.
- Apr 14, 2003
- Hessel, Michigan
Well, off to the track tomorrow, and the Attak sure looks good! SRX is ready also!
So this will also be the AmSnow shootout that was held for the last 2 years in October in Brainerd!!!! When and where was this announced? Which weekend or date? Holy sh!t, over 1700 kms, not sure if we’ll make it!!!!pro116 said:Don,the race is being held at Martin,MI.Jamie Bellman will be putting it on there all ready have an aspahlt and grass drag race there now the amsnow shoot out so it should be a huge event 3 races at one plce.
Don
Hey psssssttt, good luck this weekend Terry!!!! Need a driver (165lbs) for that SRX?????
monker
I'll be out Sunday for our first weekend here. Just test and tune so I hope to get a decent number of runs in. Of course we have beautiful weather now and they're calling for showers on the weekend. Hopefully they hold off. Saturday will be busy for me as I still have a bunch of stuff to do to get ready.
dirkdiggler
Suspended
SRXMAGIC said:GOOD LUCK BOYS!! IT'S LOOKS LIKE I WILL BE TAKEING ANOTHER YEAR OFF.
WHY?
monker
dirkdiggler said:SRXMAGIC said:GOOD LUCK BOYS!! IT'S LOOKS LIKE I WILL BE TAKEING ANOTHER YEAR OFF.
WHY?
Yeah, what he said. I thought the viper was coming out.
- Apr 14, 2003
- Hessel, Michigan
O.K. Had a crappy start with showers ending in the morning, and the officials trying to dry it up. Finally got to run after the wife showed up with the air dam for the SRX. The Attak ran good, but spun and hopped like a dolphin. And the SRX had a dead cylinder, (magneto side).
Came home early and went thru everything. Going to run the SRX tomorrow for eliminations.
Temp was 67 degrees, and humidity was 91%. Headwind of 10-14mph.
1st run - Attak (spun and hopped) lane 1, reaction .061 (.000 is perfect)
1.530 60ft. - 6.953 1/8mile @ 96.106mph - 11.214 1/4mile @ 111.889mph
1st run - SRX (new plugs, but not firing on all 3 untill revved up) reaction .023
1.804 60ft. - 6.785 1/8mile @ 104.522mph - 10.688 1/4mile @ 121.980mph
2nd run Attak - reaction .036
1.551 60ft. - 6.989 1/8mile @ 94.704mph - 11.256 1/4mile @ 111.803mph
2nd run SRX (new plugs again, and still had fuel problem) reaction .099
1.674 60ft. - 6.630 1/8mile @ 105.193mph - 10.509 1/4mile @ 122.766mph
Came home early, and cleaned out all carbs again. Must have had something in there, cause when I put it back together, it fired right up, and ran like it should. SRX should be running 9.50's
- Apr 14, 2003
- Hessel, Michigan
4/23/06 Wisconsin International Raceway
Opening day
Temp went from 50° to middle 60°s, turning cloudy with showers early, then clearing to sunny conditions. Got a late start as the track needed to be dried off.
Decided to run the SRX, and leave the Attak home to work on suspension issues.
1st time run - lane 1 (reaction .035)
1.526 60ft. - 6.277 1/8mile @ 110.313mph - 9.961 1/4mile @ 129.577mph
2nd time run - lane 2 (reaction .111)
1.570 60ft. - 6.337 1/8mile @ 109.769mph - 10.040 1/4mile @ 128.866mph
1st round - Lane choice gave me lane 1 (reaction .042, but lane 2 redlighted before I did) Dial in was 9.98
1.595 60ft. - 6.302 1/8mile @ 110.373mph - 9.988 1/4mile @ 129.398mph
(won 1st round)
2nd round - Lane choice gave me lane 1(reaction .004, lane 2 relighted -.104)
Dial in was 9.98
1.606 60ft. - 6.385 1/8mile @ 108.685mph - 10.131 1/4mile @ 127.248mph
(won 2nd round, but same carb was giving me problems again)
3rd round - Lane choice gave me lane 1 (reaction .019) Dial in was 9.99
1.554 60ft. - 6.299 1/8mile @ 110.107mph - 10.080 1/4mile @ 117.258mph
(won 3rd round on the brakes. win margin was .030)
4th round - Lane 1 (reaction -.030) Dial in was 9.99
1.526 60ft. - 6.332 1/8mile @ 109.856mph - 10.038 1/4mile @ 128.358mph
(lost by redlight)
SRX ran good untill the last round, and the magneto side carb decided to not provide fuel to the cylinder again. Hit the throttle, then it ran the 1/4 o.k., but need to clean the carbs again.
Opening day
(won 1st round)
Dial in was 9.98
(lost by redlight)
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
April 23, 2006
Marion, SD
Thundervalley Drag Way
The first two passes only slick cars were allowed to run and I got in on some decent traction. The day before they had 60+ sport compact cars show up so there was no rubber down on the track to speak of.
The sled is a 2006 Apex ER with reverse still hooked up and 103 miles on it.
1st Run: Ulmer Racing Stage 2 Kit
60': 1.485
660': 6.666
MPH: 100.532
ET: 10.681
MPH: 120.081
2nd Run: Ulmer Racing Stage 2 Kit (best pass of the day)
60': 1.467
660': 6.598
MPH: 101.92
ET: 10.580
MPH: 120.255
3rd Run: Tried softer secondary & spun worse
60': 1.57
660': 6.768
MPH: 101.298
ET: 10.753
MPH: 121.111
4th Run: Tried More tip weight with Ulmer Stage 2 Kit and spun bad, traction was going away.
60': 1.542
660': 6.748
MPH: 101.248
ET: 10.741
MPH: 120.413
5th Run: Just playing around tried more engagement rpm & more initial helix and spun some more (isn't learning fun!!!)
60': 1.607
660': 6.867
MPH: 100.920
ET: 10.864
MPH: 120.303
6th Run: Went back to Ulmer Racing Stage 2 kit primary settings with more initial helix angle and spun again but not as bad as run 5.
60': 1.532
660: 6.749
MPH: 100.985
ET: 10.762
MPH: 119.529
7th Run: Went back to same clutching as Runs 1 & 2 but tried a different spot on the starting line and was REALLY slippery!!!
60': 1.737
660': 7.080
MPH: 99.663
ET: 11.138
MPH: 118.756
Next weekend I will make some adjustments to the rear skid. I simply had the rear shock set too stiff for the traction available and didn't want to make any adjustments at the time at the track. The track is starting to break in now and show some decent wear patterns. Hopefully I can knock some more time off next weekend.
Marion, SD
60': 1.485
660': 6.666
MPH: 100.532
ET: 10.681
MPH: 120.081
60': 1.467
660': 6.598
MPH: 101.92
ET: 10.580
MPH: 120.255
60': 1.57
660': 6.768
MPH: 101.298
ET: 10.753
MPH: 121.111
60': 1.542
660': 6.748
MPH: 101.248
ET: 10.741
MPH: 120.413
60': 1.607
660': 6.867
MPH: 100.920
ET: 10.864
MPH: 120.303
60': 1.532
660: 6.749
MPH: 100.985
ET: 10.762
MPH: 119.529
60': 1.737
660': 7.080
MPH: 99.663
ET: 11.138
MPH: 118.756
Srxspec said:April 23, 2006
Marion, SD
60': 1.485
660': 6.666
MPH: 100.532
ET: 10.681
MPH: 120.081
60': 1.467
660': 6.598
MPH: 101.92
ET: 10.580
MPH: 120.255
60': 1.57
660': 6.768
MPH: 101.298
ET: 10.753
MPH: 121.111
60': 1.542
660': 6.748
MPH: 101.248
ET: 10.741
MPH: 120.413
60': 1.607
660': 6.867
MPH: 100.920
ET: 10.864
MPH: 120.303
60': 1.532
660: 6.749
MPH: 100.985
ET: 10.762
MPH: 119.529
60': 1.737
660': 7.080
MPH: 99.663
ET: 11.138
MPH: 118.756
Awesome times for first time out you will only get better as the asphalt track breaks in and it gets warmer out can't wait to see if the excell exhaust does anything for you Once you get into the 1.3 60' you will be in to the low 10's and thats great for a 150 hp sled that weighs that much, but I wish you would have left the S/C on the sled
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Allen are you running stock skid?? If you are those are still preety good numbers,sense your short time is off a little,did you deep stage,or shallow stage,i as sick today and unable to send you out the package,but i will try and get out tomorrow for you,and hopefully it will reach you for sat. trials... Pete
- Apr 17, 2003
- Menno, SD
- Menno, SD
Stone,
I'm going to try some different things next weekend at the track on test & tune again. I need to soften up the rear shock on the Wahl skid because right now it has no "bite" in it at all, just fish tails.
Pete,
My list of mods is as follows:
-Wahl Bros Skis
-Wahl Rear Skid
-10.5" Track
-2003 RX-1 Seat: $50
-2" Sportech Riser: $20 (replaced stock riser)
-Yamaha SX front shocks: $70
-Short Apex windshield
-Ulmer Racing Stage 2 Clutch Kit
I was only staging in far enough to turn both sets of lights on and after a few runs (figuring out my timing on the lights) I was cutting .540-.550 lights (.500 being perfect).
Pete,
-Wahl Bros Skis
-Wahl Rear Skid
-10.5" Track
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Allen sled looks very nice,i sent out the package today at around 10:30 ground UPS from my old dealer,and he stated that ground UPS would take like 5 days to get to you,sprry i couldent of sent it out earlier,but this flu i have has had me bed ridden.. Pete
yamahajunkie
nos-pro the runs you had on the attak, are those on the bottle? are you still running the 90-100hp? junkie
- 9K
- 33K
