blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Looking over things on the sled and noticed primary has black ring. Only 20 miles on it. Washed the belt and scrubbed it with dawn soap before installing. Secondary clean as a whistle. Clutch has big venom kit with 33-35 helix orange at 40. Any ideas. Thanks
Where is the ring on the sheave? Bottom? Pics would help
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Trailer loading and/or slipping going into garage or something.
Ignore it and ride.
Ignore it and ride.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I added more mid weight....
Must be squeezing to hard now.
300hp ss header performance exhaust xs825 belt.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Also running Nytro primary clutch.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I really don't know if its too much weight or not enough. 144 studs with 1.5 track in snow.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
KnappAttack
- Feb 19, 2004
- Welch MN
Ya, now that's ugly. I'd be curious to now the setup as that is not happy. Does the movable look just as bad in the same area?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
On the firm trails it pulls really good.
On the soft lake effect trails is when I am having issues. Feels like its pulling the rpms down.
KnappAttack
- Feb 19, 2004
- Welch MN
What is your secondary setup? Rollers? Spring and wrap?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
35 degree dalton helix, orange thunder products spring set at 3-1, hi-torque clutch rollers.
KnappAttack
- Feb 19, 2004
- Welch MN
I can't help you with the TP spring as I've never had one on my drill press scale to know the pressures, I'd suggest to put in a new Version2 Dalton Black/Orange set at 90 with the 825, or a Dalton white Cat torsion spring (same as Cat sno-pro Green) at 9&2, they both have the same pressure on my scale and will serve you well, then tune the primary to that.
I have found that the 825 really does need more side pressure than I thought after blowing two of them last week on the big tunes with the hi-torque rollers. Even on the 825 after it gets a few miles on it, it needs more side pressure.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Ok ill try that. Thanks for the help.
Once I get it set up for the 300 tune I am going to run that set up all the time even when going down to the lower tunes.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
3-1 on that TP orange spring is way to light IMO. I run it 6-3
