**sj**
as to rollers...if you get cat rollers...get the torlon ones...
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
The Yamaha replacement rollers are also flat-spotting....buy aftermarket rollers and you won't have a problem.
Riceburner doesn't like this.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Any special part number SJ?as to rollers...if you get cat rollers...get the torlon ones...
I really like the ones Ulmer and STM sell...special material with lots of hi HP history. But also the most costly.
TP has them for less, and they look to be more like my doo roller material color, which held up fine and I think many here are using the TP rollers.
I installed the Hi Torque rollers in Toms and ran them in my cat with great results, and are in Canada so can be abit cheaper up there.
Im gonna try to dig up the cat roller part number and price them out.
Dan
@123
i have turbo dynamic ones love them worth the money !!! at first only one roller was touching but afer a couple of ride now all 3 touch great stuff !!!!Any special part number SJ?
Dan
Pstn head
Thought you might need the Cat torlon roller part #Any special part number SJ?
Dan
Thunder rollers working good for me for $45
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yes the Hi Torque rollers I have used on toms SW and my cat are what Ben sells...nice stuff for sure and made in Canada.i have turbo dynamic ones love them worth the money !!! at first only one roller was touching but afer a couple of ride now all 3 touch great stuff !!!!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks, I did some googling earlier and came up with same part number. I did see some early versions of same part number that were cheaper, and dug alittle deeper to see the original model was NOT torlon material. So the part number supersedes to the new torlon. Just would hate to get the old ones by accident.Thought you might need the Cat torlon roller part #
Any chance you got a pic or two of torlons? Id like to see the color to compare to some of these others im checking out. OSP has cheapest ive found so far at only 35 so I fired off an email to see who makes theirs.
Cat shows the pic of torlons as yellow color looks to be.....
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My cat rollers are yellowishThanks, I did some googling earlier and came up with same part number. I did see some early versions of same part number that were cheaper, and dug alittle deeper to see the original model was NOT torlon material. So the part number supersedes to the new torlon. Just would hate to get the old ones by accident.
Cat shows the pic of torlons as yellow color looks to be.....View attachment 130283
saskattakman
according to the Yamaha rep the new rollers are made out of the same material just ground to size and not molded or vise versa can see why they are flat spotting..has anybody tried a new stock helix to see if they touch all 3 rollers?
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
All three of my stock rollers touch my stock helix on my 2017 Winder. I haven't had the new upgraded rollers installed yet.according to the Yamaha rep the new rollers are made out of the same material just ground to size and not molded or vise versa can see why they are flat spotting..has anybody tried a new stock helix to see if they touch all 3 rollers?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I think this is key point, if all 3 touch properly they will have a lot longer life before they flat-spot. Maybe never flat-spot.All three of my stock rollers touch my stock helix on my 2017 Winder. I haven't had the new upgraded rollers installed yet.
It would be a shame of yammie did not just make the new ones out of the same good materials as the cat torlons that seem to last and last. Or the fiber material like Hi Torque uses.
I do like the Hi torque design with there shoulder to inside and washer to outside.....theory is the outward centrif force will not rub like a flat sided roller will.
I put these in Toms last season...nice design.
IH8CROWS
How did you get them so cheap? ?Thunder rollers working good for me for $45
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Those are primary rollers here are the secondary rollers
