1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Put the tuner 3's on great ski
Bad advice here folks. Tuner 3 skis don't fit on the nytro they were made for the pro cross chassis.
they will fit but a shim needs to be added to use the stock rubbers unless you get a set of rubbers from curve witch will work with the skis.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
It's not a direct bolt on. Different width for the spindle hardware and the distance from the bolt to the ski where the rubbers sit is taller.
the width is the same as i run the sr viper skis on a pogo sled that was set up at tuner width. the spindle width is the same when measured. yes the height is taller as are the curve skis when you put them on an apex or nitro. i put a peice of 3/8" rubber in the bottom so i can use the stock ski rubbers.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I measured the inside bushing to bushing of the nytro ski and tuner 3 ski off my sidewinder.in the picture. The nytro is wider. You must be removing the ski bushings and shimming to fit on the spindle.
Not a direct bolt on.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I have the regular tuner skis on my nytro which are a direct bolt on, no modifications needed. The tuner 3 skis are not a direct bolt on.
Blownhard
- Mar 20, 2017
- Niagara Falls
- Nytro xtx
Sidewinder ltx-le
C&A n call it day
Carbide all depends on your studding
My 144" turns on a dime
Nytro08
I just put a set of mtx skis on with snow trackers at the end of last season . Didnt get a chance to ride it yet but I'm hoping it will fix the knuckle steering
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Happy w Tuner IIs and full Bergstrom setup, 80% trail... Bergstrom nailed the mods to make stock 2009+ geometry work, reverse rubbers, shim backs, triple carbide inners, wear bar outers... Like on rails, no darting or following other ruts. Love setup.
- 40K
