gerbes2
- Dec 9, 2017
- mn
- sidewinder
Maybe something different in system. This has worked perfect and simple many times in my dads and my winder every year as part on summer PMI have a compressor version of that.
It didn't work
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Sounds like you have a tough one!
I have seen one that was tough! Caliper was split and examined before trying to add #4 DOT brake fluid, and it would not give him any brake whatsoever, once filled and bleed the conventional way, fill from top and bleed through bottom bleeder screw!
Whereas I had done the reverse fill a couple of times, I offered to try.
After we were done reverse filling, we tried 2 skirts of the conventional method because we only got a slight brake afterwards!
That gave us a bit more brake but still not the just the finger touch brake he had prior, so he decided to just try taping on the caliper and master cylinder. That did not do much, so after re filling and placing the rubber diaphragm and plastic master cylinder Cover back on, we took turns just working that lever for what seemed like an hour or so! It finally gave him about 3/4 brake!
He had said that he read from someone on TY about just leaving the parking brake on overnight!
Well whatever the problem, his brake came back to 100%.
So this year I was very Leary of splitting my caliper again because of what my buddy went through, but I did. Glad to say I had no problem getting a full brake using the method I posted at beginning of this thread!
The difference between his and mine?
His caliper body (sled side) emptied, while mine just seemed to hold it’s fluid just hanging there!
We thought that an air bubble got caught in that caliper body???
So yes, some are easy to prime and bleed, others, not so!
stgdz
- Mar 27, 2021
- Buffalo MN
So I went to a dealer today and checked out a stealth master cylinder, granted it was a Polaris but I confirmed that I don't have some sort of herculean strength and could not get the poo lever to go to the handle
This is the amount of fluid I have drained via gravity bleed and also trying handle pressurization.
Still like a sponge.
Tonight I'm trying the handle strapped to the bar with rope. Should I take the cover off or leave it on?
stgdz
- Mar 27, 2021
- Buffalo MN
And one of the other things I'm considering is putting a screw driver between the pads and the cylinder and then trying to bleed it. I would take the cover off and remove some of the fluid.
I figure that may push more air out of the cylinder.
RobX-1
- Coldwater, OH
Rather than use a screw driver to pry between the pads to compress the cylinder, what I would is install the brake pad that butts up against the cylinder and then use a C-clamp around the backside of the cylinder (just some flat spot) and the brake pad so as to use the clamp to compress the cylinder in all the way. I do this when changing my car brakes and also did it on my Apex when replacing its brake pads. Just need to find a spot on the cylinder and it doesn't take much effort to compress the cylinder.
Fleecer
- Jun 13, 2014
- 2019 SRX
Cover on!So I went to a dealer today and checked out a stealth master cylinder, granted it was a Polaris but I confirmed that I don't have some sort of herculean strength and could not get the poo lever to go to the handle
stgdz
- Mar 27, 2021
- Buffalo MN
When I've done that the caliper is off the frame from whatever it was on. Some calipers have a cutout so you can you use the ram on the c-clamp.to push.the single piston in.Rather than use a screw driver to pry between the pads to compress the cylinder, what I would is install the brake pad that butts up against the cylinder and then use a C-clamp around the backside of the cylinder (just some flat spot) and the brake pad so as to use the clamp to compress the cylinder in all the way. I do this when changing my car brakes and also did it on my Apex when replacing its brake pads. Just need to find a spot on the cylinder and it doesn't take much effort to compress the cylinder.
Not sure if the procross is a dual piston
Also the dealer wouldn't try to bleed my cat, would only do Yamahas
Assholes
stgdz
- Mar 27, 2021
- Buffalo MN
What the! Disc isnt small enough on ID. What disc is that? Ot did you just put that disc on and your old was grooved or something? You could just grind that area off a new set of pads. Definitly not Ideal for braking but I always put a chamfer on my pads leading and trailing edges to stop squealing and have never felt any loss in performance so I would do it.Wonder if this is part of my problem View attachment 168004View attachment 168005
stgdz
- Mar 27, 2021
- Buffalo MN
Bdx light weight rotor, I did camfer the edges on the pads but the light weight rotor went through the pads fairly quickly.
I ordered a new set of brake pads from Dennis Kirk tonight and they should be here tomorrow.
www.denniskirk.com
DP Brakes High Friction HH+ Sintered Metal Brake Pads - SDP518SNX Snowmobile - Dennis Kirk
Find the DP Brakes High Friction HH+ Sintered Metal Brake Pads - SDP518SNX at Dennis Kirk. Shop our complete selection of Snowmobile parts and accessories including the DP Brakes High Friction HH+ Sintered Metal Brake Pads - SDP518SNX.
Turboflash
- Mar 18, 2019
- Southern MN
To me, it looks like pads are toast. From pic 1 the center of pad is bubbled/toast. Mike once posted that made his brake lever spongy.Wonder if this is part of my problem View attachment 168004View attachment 168005
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yes, that BDX disc ate those pads something fierce. Never seen pads that worn!
I never had a spongy brake, always had a firm lever, just weak brakes that didn't want to stop without a lot of effort. I just wire brushed the pads to bring back the brake performance to new. I'm on the factory light weight race disc that came on the 17 LE's. though. I'm still running the stock pads that I wire brushed and brakes are great again. Must have just been severely glazed up.
stgdz
- Mar 27, 2021
- Buffalo MN
Yeah they didn't look like that a thousand miles ago. I put the brake in because I took it on a 300 mile trip and it started to loose feeling after some high speed slow downs. Thought it was the
My kids 4000 RR has a light weight factory rotor so I figured this would be fine. That little lip on the pad was due to the inner section of the rotor being reduced in thickness.
I may give ssi a call.
Mike I remember you looking at this type of rotor, still thinking about it?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The retaining pin hole on the fwd end of pad wears and pad sits deeper and allows wear like that. Happened to mine.
KnappAttack
- Feb 19, 2004
- Welch MN
My 17 LE already comes with a race brake, I don't remember thinking about a BDX disc for any reason at all. I did buy some different pads for my sled when I was loosing braking performance, but wire brushing the stock pads brought them right back to life and one finger braking again, so never put them in.
