XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I wish I would have taken some pic when I did it. I've done it twice now. Last year to swap tracks and the rotor came off easily together with the caliper. This year it gave me some trouble so I split the caliper so I could pry the rotor off and remove them separately. It really isn't that difficult, just takes time. I would remove the plastic rotor protector under the rotor so you can have better access for getting the rotor off. its only 4 rivets and worth your time.can anyone send pics for that brake,caliper and bearing removal that be nice!!!! i never did this and i didn’t see any pics or vids that would be nice!!!
krm
- Apr 22, 2016
- ny
Was JT helping you ??I wish I would have taken some pic when I did it. I've done it twice now. Last year to swap tracks and the rotor came off easily together with the caliper. This year it gave me some trouble so I split the caliper so I could pry the rotor off and remove them separately. It really isn't that difficult, just takes time. I would remove the plastic rotor protector under the rotor so you can have better access for getting the rotor off. its only 4 rivets and worth your time.
XP123
- Dec 25, 2016
- Chautauqua NY
No I don't have any friends that's why I do everything alone.Was JT helping you ??![]()
XP123
- Dec 25, 2016
- Chautauqua NY
I left the cover off the reservoir over night and this morning it felt much better. The brake seams to be working fine now. I'm thinking that some more air worked itself out.
- Nov 29, 2009
- sabattus, maine
Every time I have a friend help me work on my sleds I end up doing it the next day by myself hung overNo I don't have any friends that's why I do everything alone.Every time I have a friend help me work on my sleds it takes twice as long as it would if I did it myself.
- Nov 29, 2009
- sabattus, maine
Same thing when i had mine apart on my ViperI left the cover off the reservoir over night and this morning it felt much better. The brake seams to be working fine now. I'm thinking that some more air worked itself out.
XP123
- Dec 25, 2016
- Chautauqua NY
Update: I rode my sled for a few miles yesterday and hit the brakes a few times and now all is well. The brake lever movement now is minimal and is very firm. The brakes are better now than ever. I'm thinking whatever air that may have been in the line has worked itself out along with the caliper has adjusted better to the pads. I bled the brakes according to the manual and I did let it gravity bleed for some time also but it still took more time than I figured. No matter how much I bled them I never achieved the lever feel I wanted until I let it set and then use them a few times. My only advise would be don't expect perfection right away you need to give it some time and use.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
When bleeding the brakes I found what worked best was to let it gravity bleed with the bleeder turned almost all the way out. It takes a while to get the caliber full.
Yup fill rezzy up put cover back on and crank the bars hard right. Open bleeder and watch. Air then trickle of fluid then steady stream. DoneWhen bleeding the brakes I found what worked best was to let it gravity bleed with the bleeder turned almost all the way out. It takes a while to get the caliber full.
XP123
- Dec 25, 2016
- Chautauqua NY
I did that and I think it's the best way to do it. Unlike a car everything runs straight down to the caliper. Even though I still couldn't get the brake lever the way I wanted until I rode the sled and used the brake a few times .Yup fill rezzy up put cover back on and crank the bars hard right. Open bleeder and watch. Air then trickle of fluid then steady stream. Done
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I left the e brake on over night after bleeding and it worked perfect. Same thing as using the brakes for a bit.I did that and I think it's the best way to do it. Unlike a car everything runs straight down to the caliper. Even though I still couldn't get the brake lever the way I wanted until I rode the sled and used the brake a few times .
Yup that always gets any last bit out for me. Just dont forget its on for more than overnight. Thats what ruined my Master I think.I left the e brake on over night after bleeding and it worked perfect. Same thing as using the brakes for a bit.
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
Just flick the break lever several times rather than pressing it in all the way.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
i don’t know guys if they’re a way to plug the hose when you remove the caliper to prevent from leaking fluid?
Dealerjohn
- Mar 26, 2010
- Labrador
Maybe.. but you will still have air bubbles. Just bleed it and have it over with.
I also found flicking the brake line and taping the banjo bolt with a wrench got a lot of bubbles out.
