stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I put 1100 miles on both the 8JP & the Gates Carbon this year.
Last year i only got 900 miles per 8JP & 500 on the Carbon.
They both look good, but i just don't want to blow a belt. It's kinda violent! And it SCARES me!
I just wanted belts to last 1000 miles then change them. ACCOMPLISHED!
17winder
- Jan 7, 2019
- Michigan
- 17 Sidewinder Ltx Se
Ill just take a shot and order that part number, compare new to old and post my findingsYou are correct part # for 17-19 are the same: 8kc-18178-01-00. Perhaps Yamaha changed the roller material and kept same part # ?? Maybe someone else can chime in and explain.
In 17 mine got flat before 500 miles. At the time there was no other choice but to go to the cat torlon rollers, which I did. Im now over 5k miles without issue.
Scratch that ^. Not paying $45 a piece for the updated ones lol
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
First belt went 680km. It exploded, but it did no damage. Second belt has 4000km and still good. Using 8jp with a little dust.
Fleecer
- Jun 13, 2014
- 2019 SRX
I think you can get 3 cat torlons for around $75 and they work well.
Mototown
- Sep 11, 2018
- Apex 40 th
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
1,046 miles on my first belt-8JP
Stock 2018 RTX SE
Only trail ridden
I'm experiencing a lot of squeeling, especially when using reverse. Is it because the 8JP is so soft, or do I need a stiffer secondary spring? I need to purchase a new spare, and I'm thinking an 8DN or Ultimax XS825 would be a better choice.
Stock 2018 RTX SE
Only trail ridden
Fleecer
- Jun 13, 2014
- 2019 SRX
Stock 2018 RTX SE
Only trail ridden
Chances are the squealing is because belt deflection is too tight.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Thanks Fleecer. I ordered an XS825 yesterday. I'll check deflection when I put the new belt on.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I run a tight/snug 825 with a not so tight chain and no gear issues and belt issue are a distant thing of the past but with that being said always check primary rollers after every ride and upper gear yearly like some have mentioned.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I've put 250-300 miles on my new 8JP and the squealing is gone. I'm thinking it was just worn out.
I'll be checking the top gear next fall when I service the sled. I will be running the chain to spec as well. I did my first service at 400 miles and set the chain to 1 turn from finger tight, thinking that it would stretch some more. I'm at 1,300 miles now and I haven't checked it since.
theewarrior
Is your clutch alignment according to hurricane tool?I run a tight/snug 825 with a not so tight chain and no gear issues and belt issue are a distant thing of the past but with that being said always check primary rollers after every ride and upper gear yearly like some have mentioned.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Never used it just brought it down to 58 with little to no float and it liked it.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I had my first one of the year yesterday! Xs825 ~~~4200km 17psi
This belt has been over 120mph for MINIMUM 100 time.
It happened at ~~~120mph , wet snow front wind in front of a TIM horton. I had a coffee while cleaning this up..lol
Belt will be replaced under warranty for 15$
Typical 998T ride stats, 2 minutes before that belt snap whit back wind 195km\h
100% TRAIL BEAST
100% TRAIL BEAST
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Quite the vents you have in that panel!! Must help!
- 10K
