- Mar 1, 2004
darv said:check the 40 amp fuse my 08 it was on the starter relay it's a big green fuse
I need to have power going to the gauge cluster so it will sweep 1st
hlmrx1 said:Did you plug the keyswitch in? I know I've forgot to do that before!!! Also check all the fuses on the right hand side, there was one in there on my RX1 that would kill the electrical.
Yep...The ones on the upper right side of the sled?.......Will do Don.
TK's
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Do you get power to the starter? They sometimes fails....
- Mar 1, 2004
rxrider said:Do you get power to the starter? They sometimes fails....
YES...The starter is fine as I tested it. the sled is compltely dead as I should have current running too the gauge cluster 1st so it can sweep and then the starter relay should let the EFI unit come on when I turn the key part way, then when you turn the key all the way it should start. pretty simple nothing I haven't seen before, there is just a break in the current somewhere and I'm yet to locate it. I will be working on it Friday.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
I hate electrical problems.... I hope you can find where the current stops real fast....
- Mar 1, 2004
Reads like its not grounding properly.
- Mar 1, 2004
Sled Dog said:Reads like its not grounding properly.
Nope 1st thing I checked Rod.
I still need to check those upper fuses
Yamaheart
Did you get that rocket running yet Larry
I went for a rip last night decent amounts of snow out there.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Kill switch pulled up?
- Mar 1, 2004
kinger said:Kill switch pulled up?
Yes... up and also checked to see that it was working as power going to and coming out of it.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Faulty ignition key switch?
- Mar 1, 2004
rxrider said:Faulty ignition key switch?
I was actually hoping that was it, as that would have been a real easy R&R fix
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I have 08 apex and it was dead and i found the 40 amp fuse was blowed an it was located on the starter there where 2 10amps one before and on after. relay cover with a rubber strap and when I replace it i had power it is a big green fuse
- Mar 1, 2004
darv said:I have 08 apex and it was dead and i found the 40 amp fuse was blowed an it was located on the starter there where 2 10amps one before and on after. relay cover with a rubber strap and when I replace it i had power it is a big green fuse
Yep been there done that....See page #18, I have the Starter Solenoid right out of the sled and I have continuity at both poles. and the main fuse was fine as the other is a spare and it also is fine. The Starter is fine as well and working.
Don had a bad fuse in the upper fuse box and had the same problem as me, so for now I still need to check that. If there still is No Power...I'll have to call in the Big Gun Brian O...aka SRXTWINS for Factory Support
Well just throwing this out there but could there be a drain in stator or rotor?
