Wire it open and don't look back. It doesn't do crap. You will never feel it seat of the pants.Both of my cables just broke when doing the test, right at the valve cable end.
Is the EXUP valve supposed to rotate all the way around without the cables on it when spinning by hand?
I thought I saw somewhere the valve has travel stops. I’m afraid to pull the valve out as one of my bolts on the cover was seized and snapped off. I’m afraid to snap off the bottom ones on the valve itself as they’re no accented to retap.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
To each their own, but I disagree, my cables were broken when I got my 2013. I replaced and adjusted them and it was a noticeable improvement in low and midrange torque. It also idles better. Obviously it is not going to affect the top end range of throttle.Wire it open and don't look back. It doesn't do crap. You will never feel it seat of the pants.
Well I have 2 full systems and cables in my shop that I would sell if you think its worth it.To each their own, but I disagree, my cables were broken when I got my 2013. I replaced and adjusted them and it was a noticeable improvement in low and midrange torque. It also idles better. Obviously it is not going to affect the top end range of throttle.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Same happened to my 2012. If you're in a pinch, wire the exsup open and ride it till you replace it. Exsup adds some low end to the curve. No difference on top end.
