jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Pictures ?I recently went this route. Word of caution anyone using them, the carbide tip when in stored position, using the supplied mounts without alteration, stick under the tunnel. You would think geesh they are miles away from track, but, if you hit large bump or ride 2-up at all, the track coming around with hit the tip of scratchers. Took me a while to figure out what the hell was making that noise. SO, i just rode all day with them down lol. I think they throw snow bit too far back as well, might still be fine but i stood up and looked back and the rooster tail is way back. By looking at the picture of jonlafon1's here, looks like the keeper has been bent outwards slightly to prevent the tips from being stuck under the tunnel, am I wrong jonlafon?
shawnj
I think mine look the same other than yours look like they point outward a tiny bit more. If you see my other post reg bottoming out, maybe that’s why I have issues but ya I definitely hitting them and sounds horrible.Not sure how you hit them? Where I mounted mine the track can’t hit them. To bottom out that far I would have to jump off a building. Did you mount the tab that holds them backwards? Like so they angle inward towards tunnel?
I mounted some this season and I have to admit I haven't been reading any post on here in quite some time other than PM'S. I didn't know my bud Jon had mounted these or I probly would have done them up exactly the same, but not knowing I mounted mine in the most forward slot in that upper idler bracket. I wanted them as far forward as I could get them. As it turns out I never needed them on my 8 day trip to the County, but I'm still glad they were there just in case.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
They work awesome. The snow gets kicked up onto top of rear track. Thrown right into heat exchanger. I tried them all over the years. By far the best IMO. THE tips do wear out if you use them a lot. My riding crew sometimes just used 1 down and it was enough.I mounted some this season and I have to admit I haven't been reading any post on here in quite some time other than PM'S. I didn't know my bud Jon had mounted these or I probly would have done them up exactly the same, but not knowing I mounted mine in the most forward slot in that upper idler bracket. I wanted them as far forward as I could get them. As it turns out I never needed them on my 8 day trip to the County, but I'm still glad they were there just in case.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Can you post pics ?I think mine look the same other than yours look like they point outward a tiny bit more. If you see my other post reg bottoming out, maybe that’s why I have issues but ya I definitely hitting them and sounds horrible.
shawnj
I will see how much ice is on them and get a pic.Can you post pics ?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Mainly the bracket that holds the scratcher in the up position. Seems maybe you have the bracket mounted incorrectly. The plate is mounted so the holder is outside the tunnel.I will see how much ice is on them and get a pic.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I will post more pics today. I have 3 sleds with them on here in the UP.
shawnj
#*$&@ I riveted the the inside underneath.I will post more pics today. I have 3 sleds with them on here in the UP.
I also have the black snow deflectors on which I would have to remove in order to river the holders in the outside. And likely notch them out.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I will post some pics soon as it’s getting light.
shawnj
Awesome thank you!I will post more pics today. I have 3 sleds with them on here in the UP.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
shawnj
Ya yours are tucked in pretty good. Your brackets are mounted on inside same as mine. Perhaps I put the wrong bracket on the wrong side. Heading out to check.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I don’t think I would hit them if I bottomed that hard. Sounds like if your bottoming that bad you need different torsion spring in back.
- 8K
