earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The bent version has a slot.
So I haven't had mine down yet. Does anybody have a picture of the tips with good wear?
Has anyone tried these BRP tips on the rail mounted Yamaha ice scratchers?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Didn’t know Yamaha has rail mounted scratchersHas anyone tried these BRP tips on the rail mounted Yamaha ice scratchers?
These.Didn’t know Yamaha has rail mounted scratchers
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Those are the old style uni-directional ones, BRP switch to the kind with two wound coils so they can run in either direction, no need to lift up to reverse.
Yes, I just have a new set left.Those are the old style uni-directional ones, BRP switch to the kind with two wound coils so they can run in either direction, no need to lift up to reverse.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
OR drilling and tapping a hole on the other side of the wear puck that goes on the end of the wire?I think the easiest way to modify them would be to grind a "slot" in the rod so the set screw would hold the tips in place without ultimately getting loose and falling off.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
This is what I mean when I say mine gets used on a 45 degree angle. Swap left to right will get more life out of mine.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
Do you have more pictures of these installed? And I know it's been a few years. How did they hold up?My buddies have been running these tunnel BRP Ice Scratchers on their Poo and Doo's last year with great results and doesn't beat up the paint on the skid like the wire ice scratches seem to do.....at least for me. I thought if these work for Poo and Doo, they must work on Cat and Yamaha.
Very easy install. BRP part #860201516
Only addition to what came in the kit was to purchase two shorter bolts from which came in the brp ice scratcher kit. The bolt that I used to mount the ice scratchers was: M10X1.25X90. This bolt essentially replaces the stock hex bolt that is in the hanger now for the upper idler wheel. I then had to drill one hole for the spring to feed into at 2 o'clock. Then you need to Drill two holes in the inner side of the bumper under the tunnel and use two rivets that came with the kit to hang the ice scratchers when not in use. Very easy install and has great down pressure and won't scratch my rails!
Turboflash
- Mar 18, 2019
- Southern MN
I'm sure you know this but the further forward scratchers are mounted, the better they work. Scratching up snow behind the sled doesn't do any good.
Have you considered Duraflex? No problem with backing up with them down, carbide tips for long life, not in way adjusting track, etc.
betweenthelinesdesigns.com
DURAFLEX ICE SCRATCHERS™ - Between the Lines Designs
USPTO PATENT NUMBER US-7918298-B2 The innovative DuraFlex Ice Scratchers™ by Between the Lines Designs™ uses a durable steel cable in its design. We use hardened steel ends and a carbide tip. To ensure our corrosion proof design our scratchers undergo a zinc plating or “galvanization” process...
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Sorry have to disagree slightly here. The BRP scratchers have been the best in our group hands down. Most times you only need one down that's how efficient they are. The mounting of these creates a TON of snow that's kicked up and onto the track which throws into exchangers instantly.I'm sure you know this but the further forward scratchers are mounted, the better they work. Scratching up snow behind the sled doesn't do any good.
USPTO PATENT NUMBER US-7918298-B2 The innovative DuraFlex Ice Scratchers™ by Between the Lines Designs™ uses a durable steel cable in its design. We use hardened steel ends and a carbide tip. To ensure our corrosion proof design our scratchers undergo a zinc plating or “galvanization” process...betweenthelinesdesigns.com
The snow is being thrown into this area
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I get complaints from the guys behind me about the cloud. Never had any heat problems with the BRP scratchers.Sorry have to disagree slightly here. The BRP scratchers have been the best in our group hands down. Most times you only need one down that's how efficient they are. The mounting of these creates a TON of snow that's kicked up and onto the track which throws into exchangers instantly.
Turboflash
- Mar 18, 2019
- Southern MN
I agree, that's where we want snow to go. Without saying it right, I was more referring to allot of ski-mounted stuff or scratchers that don't make a cloud behind sled.
Often, I too only have to have one down.
Can you guys back up ok with those? Don't they get caught by track or go under track?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No problems backing up the few times we have.I agree, that's where we want snow to go. Without saying it right, I was more referring to allot of ski-mounted stuff or scratchers that don't make a cloud behind sled.
