Didn’t know Yamaha has rail mounted scratchersHas anyone tried these BRP tips on the rail mounted Yamaha ice scratchers?
These.Didn’t know Yamaha has rail mounted scratchers
Yes, I just have a new set left.Those are the old style uni-directional ones, BRP switch to the kind with two wound coils so they can run in either direction, no need to lift up to reverse.
OR drilling and tapping a hole on the other side of the wear puck that goes on the end of the wire?I think the easiest way to modify them would be to grind a "slot" in the rod so the set screw would hold the tips in place without ultimately getting loose and falling off.
