Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Have the manual been updated for 2015 ?
harell
- Apr 7, 2014
- Northern Ontario
- 2104 SRViper XTX SE
Picked up my machine today no charge. Area rep admitted to dealer that there are problems with the chaincase. Dealer changed everything inside the chaincase plus the right side case. Sounds a lot better now hope it stays that way. Thank you Yamaha and Brian. Dealer suspects chain tensioner to tight, set to owners manual but still too tight should be finger tight and back off 1.5 turns not .25 turns.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Is this issue occurring on all Viper model years? Any '15s having this problem?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
2015 manuals are correct
yamahaguy
Ride SAFE
- Apr 20, 2014
For the guy's having the wrong manual I'm sure that you're dealer can order one under warranty if you really wanted the correct information at no cost to you. Its worth asking.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
What does the 2015 manual say ?2015 manuals are correct
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Here are the bearing that went into my chain case.
This is the upper Wobble Bearing replacement:
Here is the lower bearing replacement:
Can this get posted in "just the facts" so I can find it later.
This will probably be 27 pages back by the time I service my sleds and want to use it.
Its in there already. Wobblebearing Replacement
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Still wondering what the manual says on the 2015.
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
- 2015 Viper MTX 162 Turbo
Back up sled AC M7
read through the thread it's mentioned more than onceStill wondering what the manual says on the 2015.
QUOTE="harell, post: 1222547, member: 22070"]Picked up my machine today no charge. Area rep admitted to dealer that there are problems with the chaincase. Dealer changed everything inside the chaincase plus the right side case. Sounds a lot better now hope it stays that way. Thank you Yamaha and Brian. Dealer suspects chain tensioner to tight, set to owners manual but still too tight should be finger tight and back off 1.5 turns not .25 turns.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
harell
- Apr 7, 2014
- Northern Ontario
yamaha's 2014 service manual states 1.5 turns out. would have been nice to know
vibeline
- Dec 31, 2007
- 2016 ZR7000
Is this still a problem on the 2015's?
Have they updated the chain case for 2016?
cheers
cheers
Zrxpilot
Just spent a couple minutes at Eckland Yamaha parts. I wonder if Yamaha isn't privy to this issue. Check out what item #1 contains. That's an awful lot of parts for a 120.00 bucks.
http://parts.ecklundmotorsports.com/oemparts/a/yam/53307294f870024560f03fc8/track-drive-2
Case, both bearings, clips, seals, adjuster.....
Im fine with that. Discover an issue they have no intentions of fixing after warranty but at least make the price of parts reasonable. I ran into that with my Phazer. Tunnel Block off kit was cheap, cooling fan was cheap. Some common bug on my Nytro was also cheap to purchase.
I see no revised part numbers for the bearings.
vibeline
- Dec 31, 2007
- 2016 ZR7000
Wow that's cheap...
must be a mistake!
