RAMSOMAIR
So true. Let’s just see what we can get away with attitude
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
If that was all sealed in the package it may have been damage from a machine used to install the bushing etc.usually if it was installed&returned the packaging would show it&believe me they don't check returned items as well as they should.i would say it was tooling marks right from the supplier&obviously wasn't checked.thats why the parts people are so important to be really on their game&catch these mistakes before they get in the customers hands!!View attachment 146063 View attachment 146064 Ordered top 22T gear , top bushing comes damaged from cat factoryIt probably won’t hurt it but its definitely not Japan quality
Ripped into the chain case for the 3rd time this season to check on the tesioner, only to find it was just fine with 2400 miles on it. Yanked it out and welded it anyway. It is no problem at all swinging the oil tank out of the way to get at the tensioner.
RAMSOMAIR
fourload
That chaincase looks clean! Is that red oil ATF.Ripped into the chain case for the 3rd time this season to check on the tesioner, only to find it was just fine with 2400 miles on it. Yanked it out and welded it anyway. It is no problem at all swinging the oil tank out of the way to get at the tensioner.View attachment 146080 View attachment 146081
Been using this stuff for years. Nice and clean and if it leaks you'll know real fast what it is due to the bright red color.
https://www.ebay.com/itm/Spectro-Pl...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Too many parts to this Cat case. I would bet if Yamaha designed it you would see something like thisRipped into the chain case for the 3rd time this season to check on the tesioner, only to find it was just fine with 2400 miles on it. Yanked it out and welded it anyway. It is no problem at all swinging the oil tank out of the way to get at the tensioner.View attachment 146080 View attachment 146081
![d5bd6eacf37f63c568bf4fe66c2a9d43.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20190210%2Fd5bd6eacf37f63c568bf4fe66c2a9d43.jpg&hash=1c766b0da6977ce4b0fab66a2233a1ce)
RAMSOMAIR
Wow, that is simple. Due in part to no reverse required as the motor spins backwards!! Oh, and look at that nice U shaped seal around the lip......just like Yamaha of old!
XP123
- Dec 25, 2016
- Chautauqua NY
This is on the 900T, no motor spinning backwards here.Wow, that is simple. Due in part to no reverse required as the motor spins backwards!! Oh, and look at that nice U shaped seal around the lip......just like Yamaha of old!
RAMSOMAIR
So reverse is the smaller sprocket below jackshaft? How is it actuated?
XP123
- Dec 25, 2016
- Chautauqua NY
See the big washer at the top gear? There is a fork that fits over it. Also look at the long threaded bolt on the chain adjuster. You can adjust your chain using a screwdriver while sitting on your seat. No lock nuts or anything. You can adjust your chain in 10 seconds and I'm not exaggerating.So reverse is the smaller sprocket below jackshaft? How is it actuated?
RAMSOMAIR
Gotcha! so electric actuator on the outer case I presume? Stop making a case for Doo, damn it lol.
XP123
- Dec 25, 2016
- Chautauqua NY
No electric actuator on X or XRS pkg. Look at the upper left of pic and you can see the manual lever. I don't like the electric reverse because they have had issues with them. The lever is very simple and now very easy to use. You pull up on it rather than down like the older design. Much less effort to use.Gotcha! so electric actuator on the outer case I presume? Stop making a case for Doo, damn it lol.
The whole point of the pic I posted is a much simpler and more reliable design is possible. There is no reason for them to stick with these outdated designs. I know for a fact if Yamaha was truly involved with designing these sleds stuff like this would not be on their sleds.
Conedodger
- Mar 2, 2017
- Tulsa
- shopping, blew up my 07 MachZ1000
Related note, Gary's Yamaha in Caribou, ME is my dealer. Last trip up my tensioner adj bolt had loosened up (another thing to watch, jam nut needs more torque than you would think, It's now a flashlight check every ride etc), oil had leaked out, gotten low, chain ratcheted. so I left the sled there for him to open it up and go thru it as I knew the shift fork shoes were compromised.
I saw this thread this am. texted the link, yes on a Sunday, to my contact (he's cool that way, has a side biz and stores my sled for the year) and he texts me back "We already tack welded both screws". That's why I buy where I ride and let them do the work. They already are at the front end of the learning curve. Score one for a great dealer.
fourload
Thanks, I think I will try it next time my case is apart.Been using this stuff for years. Nice and clean and if it leaks you'll know real fast what it is due to the bright red color.
https://www.ebay.com/itm/Spectro-Platinum-SYN-SNO-Chaincase-Oil-100-Synthetic-75W90-12oz/292743981160?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
