Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Usually the orange (brown)are viton &designed for higher heat,they may have determined the black wasn't suitable for temperatures being seenAppears that 2018 got an updated seal on the chaincase outer. The original one in post and this new one are orange and look fatter than mine on my 2017 which is black.
RAMSOMAIR
you are right about the high temps. this case is a boot heater.
![](/styles/vip.gif)
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The older Cat tensioner seems fool proof. Has anyone heard of a failure in one of these?
Yes, they had many failures and the reason they went away from it and went manual. Wonder however if we could use the pad instead of the roller, but tack welding the screws will work too.
Mototown
Mototown
![](/styles/TYLifeMember.gif)
I would not run that.View attachment 146063 View attachment 146064 Ordered top 22T gear , top bushing comes damaged from cat factoryIt probably won’t hurt it but its definitely not Japan quality
Mototown
I will check it on the shaft when I get it a part to tac the tensioner. I had order from the county cat in Minnesota, back ordered until April up hereI would not run that.
Brotherdan
- Sep 8, 2017
- Belmont,maine
That obviously missed qcView attachment 146063 View attachment 146064 Ordered top 22T gear , top bushing comes damaged from cat factoryIt probably won’t hurt it but its definitely not Japan quality
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Neither would I. It looks like someone else tried to put that on a shaft and messed it up. Did the box look to be opened previously?I would not run that.
BTP
- Jan 5, 2018
- Michigan
- 2018 Thundercat, 2019 Thundercat
Those are marks from a spline. That has been on a sled.... That's not a Cat issue that's someone screwing the part up and sending it back.
swampcat
That looks like dog crap. Send it back. Or at least send them a picture of it, then let them make the call.
Yes if the base metal is distorted it will groove your shaft and it sure looks like it is.
RAMSOMAIR
Bahahahahahahahahahahaha missed QC, thats a good one!That obviously missed qc
Mototown
No , the packaging clearly looked original, I would bet it was from factory the way the bubble wrap was .
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I think this whole thread is about QC or lack of.Bahahahahahahahahahahaha missed QC, thats a good one!
