putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Wow 4000! Something is wrong. No worries. Will figure it out. Yes. Next weekend Hazelhurst. PM me the details. Gonna get you dialed in and then take you to the Harrison Hills trails. My favorite trails in WI!
Just did the Harrison Hills ride today! My favorite trails by far too Cannondale! Shhhh....don't tell to many people about this place.
You lucky bugger! Havent been there yet this year. Love the jumps and hills!
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
My squeal is mostly the tight deflection of the belt riding the shaft. It starts quiet and gradually get loud. Not to loud.. I have what looks like no more then usual belt dust and no black makes on the sheaves. What I saw early was a slightly cleaner/polished area. My rpms run around 6-7k at 60mph. My biggest issue is the belt is riding high in the secondary and have all spacers removed. Ulmer thinks he the beginning tolerance and what he machines might have been to much. I have another setup sent to me by Ulmer but won't be able to mess with it until the end of the week. Currently in the up riding. The belt rides to around an inch from the top but sometimes might get to quarter on the primary. Which I blame on the secondary belt height.
Subaru2006
Subaru2006
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Just find some longer bolts to put in the secondary. Better yet would be OSP adjuster. The high belt has nothing to do with anything once it starts shifting. Here is pic of how slipping belt looks on secondary. This was eliminated by 3-2 wind on that red spring or going back to pink shimmed.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I have no secondary slip. Or at least it doesn't look like that. Mine looks like my primary. I'll check again in the sun tomorrow.
Subaru2006
Subaru2006
Subaru2006
Right you dont. Thats what I was showing.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
But my looking and thinking again my secondary being wrapped 6-2 being tight won't let the belt get lower in the secondary to raise it on the primary for full shift? Correct?
Subaru2006
Subaru2006
Studroes144
- Oct 30, 2013
Subaru2006
Correct, too stiff of secondary wrap and it'll stop the secondary from shifting and the primary may continue to shift a bit or try to and that's where the belt dust and burn marks are coming from
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
See that's the thing. No belt dust really and no burn marks.
Subaru2006
Subaru2006
Then you didnt hold it tight long enough. Pin it and you will see.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I've had to at 90 for a few times now. Very consistent compared to before. I've held it there enough to keep it topped for awhile.. No lakes or anything..
Subaru2006
Subaru2006
Thats not too bad. What rpm you at?
This sucks! No wonder there is so much inconsistancy!
http://www.ty4stroke.com/threads/primary-clutch-change.133193/
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I'm lower then were i want. Just by look and no recall it s 87-8800.. I would think that's the primarys fault with weights?. Should I wrap the secondary to something other then ulmers stock which I think is 6-3 or 6-2?. I really wish I knew.
Subaru2006
Subaru2006
- 16K
