TheFarm845
- Jan 19, 2022
- Minnesota
- 2022 Sidewinder LTX LE
I scored a nearly-new BMP full velocity muffler for my 22 LTX. BMP said they recommend their clutch kit to bring the rpms back down due to the muffler. However, I just came across a post from a couple years ago while searching other things and someone mentioned that the Ultimax XS825 will bring your rpms down by 400-500 because it won't slip like the stock belt. Soooo is that true? Seems like a lot. And if so, can a guy just run that belt instead of buying weights and springs?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I'd say more like a drop of 3-400 but yes you can just run that belt to drop the RPM.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Do you have a tune?
TheFarm845
- Jan 19, 2022
- Minnesota
NopeDo you have a tune?
DMCTurbo
- Nov 12, 2005
A high flow muffler is going to cause the engine to run lean. Most aftermarket mufflers will require a tune. You best speak to BMP. I'm not familiar with that exhaust.Nope
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
20-25 hp increase with no tune required?
bikemanperformance.com
Arctic Cat 9000 / Yamaha Sidewinder - Full Velocity Exhaust (2017+)
Fits 2017-Up Arctic Cat 9000 & Yamaha Sidewinder Models A HUGE 20-25 HP Gain No fuel or tuning changes required Our Stage 2 clutch kit is highly recommended A must-have for any sled with tuning Weighs only 10 lbs. Great fit and finish Available in bare stainless or ceramic chrome Need a...
TheFarm845
- Jan 19, 2022
- Minnesota
Bikeman Performance. I called them and they assured me I won't need a tune, its a 2.5" trail muffler. Just highly recommended to clutch it to pull rpms back down. They make tons of products for 2 stroke sledsA high flow muffler is going to cause the engine to run lean. Most aftermarket mufflers will require a tune. You best speak to BMP. I'm not familiar with that exhaust.
TheFarm845
- Jan 19, 2022
- Minnesota
Apparently. That's what they showed on their dyno. That was on a first year 998 thundercat.20-25 hp increase with no tune required?![]()
Fits 2017-Up Arctic Cat 9000 & Yamaha Sidewinder Models A HUGE 20-25 HP Gain No fuel or tuning changes required Our Stage 2 clutch kit is highly recommended A must-have for any sled with tuning Weighs only 10 lbs. Great fit and finish Available in bare stainless or ceramic chrome Need a...bikemanperformance.com
DMCTurbo
- Nov 12, 2005
My 6 years experience with these sleds tells me otherwise.Bikeman Performance. I called them and they assured me I won't need a tune, its a 2.5" trail muffler. Just highly recommended to clutch it to pull rpms back down. They make tons of products for 2 stroke sleds
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Their dyno inflates their products performance far greater than you will ever see if compared on someone elses dyno. They are well known for their overly optimistic dyno. If it in fact runs without a tune im guessing its less than 10hp. For less than the price of that muffler you can buy an 230hp ecotrail stock muffler tune or a 225 stock muffler tune from hurricane and get way more power……safely.
TheFarm845
- Jan 19, 2022
- Minnesota
I bought it mainly for a little more sound. I have a 4 year warranty so I don't plan on a tune. I honestly could care less if the gain is only 2hp haha. I only paid $275 for it with less than 100 miles of use on it so it was hard to pass it up
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The XS 825 belt will probably pull your rpm down real nice with that muffler. I would definitely try that first. Otherwise if it doesn’t work go with a adjustable weight from thunder, Dalton or DD.
TheFarm845
- Jan 19, 2022
- Minnesota
Perfect, because I already bought a XS825 as a spare, so I'll just swap it out before riding next season!The XS 825 belt will probably pull your rpm down real nice with that muffler. I would definitely try that first. Otherwise if it doesn’t work go with a adjustable weight from thunder, Dalton or DD.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
As others have said, you should have a tune with that muffler. I think Bikeman is giving you bad advice unless the muffler they sold you flows close to stock levels.
The XS825 will bring your RPMs down. No need for clutch weights.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Start by just adding the muffler and nothing else.
If it over revs, it’s doing something. If not, you need nothing more!
8750 is stock revs, but I always have preferred 8850.
Does Bikeman give a target rpm for their No Tune exhaust?
- 9K
