shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Great job yamamarc.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
thanks any mistakes?(besides spelling..lol)Great job yamamarc.![]()
I will add the torque values shortly
- Apr 14, 2003
- Hessel, Michigan
Very well done bud!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
We are in the middle of a snow storm right now In about an hour I'm going for a boot on the lake to try it out!!!Very well done bud!
I'm just the parts changer you guys are the brains behind it all!!!
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
Very good write up!
The only things is you don't need to remove the seat and the plastic that wrap around the gaz tank, but if you feel more comfortable by having more space, then its a nice thing to do!
Have fun!
Have fun!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
You're right thanks!!! I will edit it as optional!! I just liked having the roomVery good write up!
Have fun!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just got back from a test run I gotta say very impressive!! I went on the lake conditions wasn't the best 6" of fresh snow, difts and slush but I had a blast!!! I couldn't do any top end runs but from the time I hammered the throttle to the time I let off it pulled like a freight train. I checked my max rpm's and it showed 9001
. Hopefully by tomorrow enough sled will run the ice so I can try it on some hard packed! I stuck with my original belt 8jp I didn't set up for the 8dn yet( want to break in the 8dn before hammering the throttle)
. Hopefully by tomorrow enough sled will run the ice so I can try it on some hard packed! I stuck with my original belt 8jp I didn't set up for the 8dn yet( want to break in the 8dn before hammering the throttle)yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Does the COTC kit use the stock belt?...is someone selling this kit as a complete kit?
stingray719
Okay here is a step by step installation of stingray"s cotc kit
this was my first time ever doing any mods to a sled it was pretty simple to install!
To keep thing as accurate as possible if you experienced guys see any mistakes please let me know so I can edit!
First I removed the side panels, seat, the black plastic cover that wraps around the gas tank and removed the belt(note: the removal of the seat and black plastic cover that wraps around the gas tank is optional I liked the extra room)
Second I took the primary clutch cover off by removing the 6 bolts(10mm socket)
Be careful there is pressure from the spring I just kept one hand on the cover to remove the bolts
3- remove 1 weight at a time
place something under the clutch to catch any parts that you may drop accidentally
remove the clutch weight bolt( 10mm socket 1/4 inch drive with a universal and 10mm wrench)
then loosen the 2 allen head set screws that hold the pin(2.5mm allen wrench)
slowly remove the pin holding the weight and the white washer on each side of the weight
4-Grab your new weight (I installed the 3.6g rivet at the tip) and install it making sure 1 white washer is on each side
center the pin tighten the set screws and install the bolt(torque@ 4.3ft/lb)
do the same for the other 2 weights
5 I installed 4mm shims in my clutch cover and a new spring
6- Reinstall the clutch cover make sure you line up the x on the cover with the x on the clutch (balance) and install cover(torque the 6 bolts@ 10ft/lb)
GREAT WORK!
stingray719
Page one, first post has that info
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
thanks you again for your help and direction!!!GREAT WORK!
I got the "mod itch" now!!!lol I'm going to definitely throw a aftermarket can in it and possibly the reflash that evo is working on!!
stingray719
Can you also put this in a separate post titled something like "Clutching On The Cheap install with pics" and maybe cannondale can make it a sticky?
stingray719
Air box mod will give you a big mid range boost and is free. I know don't encourage the "mod fever"
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Is there a thread on this somewhere StingrayAir box mod will give you a big mid range boost and is free. I know don't encourage the "mod fever"![]()
you are starting to remind my of that little devil on my left shoulder!!!lol
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
do you mean start a new thread?Can you also put this in a separate post titled something like "Clutching On The Cheap install with pics" and maybe cannondale can make it a sticky?
