Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Must say I'm impressed .viper has been sitting outside for days and this morning at -25f with it pointing into a slight north wind it fired on second turn of the key.was a little stiff but it went.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
-15f and went to unload it off the trailer this morning, First attempt of about 6-7 seconds,nothing. Second attempt about 3 seconds in it started catching on one cylinder and took another 1-2 seconds of cranking for the rest to catch fire. My Phazer right next to it, 2 seconds and popped right off......... then died a few seconds later, second attempt popped off instantly and stayed running. Not sure I like how long it takes to start firing, but my Phazer hasn't been good frigid morning starter either and takes 2 attempt usually. At least it doesn't take a lot of cranking before it fires. Hot start or 10f+ the Viper fires up at about 2 seconds, Phazer fires instantly.
Carla 123
- Feb 27, 2017
- Manitoba
Well went out this morning and at -34 c would not go.ended up using the booster pack and even then had a real tough time getting it to start.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
It would be interesting to see if anything helps with extreme temperature startups.
Temperature?
How long it sat since last ran?
ECU flash?
Stock spark plugs?
Type of engine oil?
Fuel type, non ethanol?
Stock battery or aftermarket?
Booster used?
Temperature?
ECU flash?
Stock spark plugs?
Type of engine oil?
Booster used?
Carla 123
- Feb 27, 2017
- Manitoba
2 days since it last ran.parked outside .87 ethanol fuel .stock plugs.flash unsure of.400 amp power pack to start and almost drained that.going to park in the shop from now on .lol.will never leave home without the booster.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Successful attempt? Yes
Temperature?-38 F overnight but around -32 F during start attempt
How long it sat since last ran? Overnight
ECU flash? 15 flash
Stock spark plugs? Yes
Type of engine oil? Mobile One 0w40
Fuel type, non ethanol? 87 10% ethanol (treated with a Lucas Oil additive)
Stock battery or aftermarket? Stock
Booster used? Yes, booster put on before attempt.
Additional comments: Connected the booster on the battery before attempting to crank it. Engine turned over and fired but took a couple of attempts of extended cranking before it started. I also have updated all the relays to what is suppose to be a better sealed mechanical relay (Mfr# 303-1AH-S-R1-12vdc, Mouser Electronics # 893-3031AHSR112VDC)
ECU flash? 15 flash
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
Traveled for an hour with 2014 Viper on open trailer at -34C. I cranked it a few times with no results. Then it fired and ran for a few seconds. I cranked it again and it ran. I couldn't believe it! I just had the most recent flash a few days ago and it fixed my speedo, idle speed and now starts on first attempt. I'm impressed to say the least.
Dicker from JP
- Nov 12, 2014
- Jacksons Point,Ont
- 2015 srViper l-tx se
I just got the latest flash two weeks ago. Haven’t ran my sled since I got it done and has been sitting outside the whole time in the trailer. Tried starting yesterday in -15 and would not go and drain my battery . Hooked Power pack up ,crank for seven seconds nothing ,crank for another seven seconds nothing ,crank for the third time for about three seconds and it fired up . If I’m going to be honest , I’ve never owned a sled that I’ve been so scared to crank the key on before .. I’m mean with the starter at first and now this cold start business.. Don’t leave home with out a power pack.. seriously !!!
Carla 123
- Feb 27, 2017
- Manitoba
My friends vector was outside and it would not go either.his cat and nytro fired up but they were in his shop.got mine in the shop now and see if it will start tomorrow morning.if it doesn't start. back to the dealer.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
My friend had the same issue with his viper one day with similar temps. If there is any moisture in the relays I think you are in trouble
When in the shop try some heat under the hood with a space heater
Those are some pretty crAzy temps
Ms
Ms
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
Ive been lucky..i think it was -34 the one time we spent a weekend up north, sat outside uncovered and it started like normal...aside from the gauge until it warmed up lol.....now i do have a different battery and plugs and mine is always on the battery tender
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
My own personal opinion is that the battery location is a very large part of the issue with cold weather starting. The size of the cables required to reduce voltage drop under load during extreme cold is also an issue. The battery is located to far from the starter and the connecting cables between are undersized for the VD. The cables are rated for the current however at a cost to the supply voltage.
I had five sleds all in the same conditions, three Apexs (two 2012 and one 2011) and two SR-Vipers. The Apexs started as they always do in extreme cold with some cranking but the rpm of the cranking was not diminished from the cold. The SR-Vipers tried to start but the cranking was so slow that they would not turn over. Hooked up cables to a truck, effectively removing the voltage drop and they fired off better than the Apexs. I have always thought that the battery located at the rear, as far away from the starter as was a ridiculous idea and a design issue that should not have been over-looked. I really wish someone would develop a battery relocation kit for the SR-Viper all models.
Carla 123
- Feb 27, 2017
- Manitoba
Makes perfect sense but you would think after making sleds for 50 years and a winter vehicle at that .that they would start.My own personal opinion is that the battery location is a very large part of the issue with cold weather starting. The size of the cables required to reduce voltage drop under load during extreme cold is also an issue. The battery is located to far from the starter and the connecting cables between are undersized for the VD. The cables are rated for the current however at a cost to the supply voltage.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I'm not sure if I total agree with the battery location being the issue. I installed a Nytro motor and electronics in the Viper chassis with the battery still in the same location and it doesn't seem to have any start issues. So far it has started as if it was still in the Nytro chassis. This has been discussed heavily in other threads so lets not go there again.
Yup.I'm not sure if I total agree with the battery location being the issue. I installed a Nytro motor and electronics in the Viper chassis with the battery still in the same location and it doesn't seem to have any start issues. So far it has started as if it was still in the Nytro chassis. This has been discussed heavily in other threads so lets not go there again.
