**sj**
I did it on my 2012...you will save about 7 lbs and a lot of rotating mass....Im sure scott taylor has what you need
when i saw how the actuator goes in on this, i thought of using 2 peices of flat bar to hold it in forward using the existing mount holes and weld a t onto it that holds it in forward when bolted down.
Team Tonka
I did it on my Cat. Used a sharp edged fine and made a groove on the jack shaft. Then used a snap ring to hold the gears firmly together. Then removed all reverse parts.And maybe a few miles a hour faster? Really just don’t use it. I would think one less thing to go wrong. Thanks will check into Hurricane and see.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I would be interested in doing this because of the upper gear bushing wearing out. You really almost need a splined jackshaft and matching upper gear tho.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I’m trying a new Cat gear with three oil holes....and surprise they are drilled all the way through now. Any info if they are holding up?
They do seem to be on the Winders. 15w chain helps too.I’m trying a new Cat gear with three oil holes....and surprise they are drilled all the way through now. Any info if they are holding up?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Ok thanks Cdale, I have the 15 wide now also. So I guess I’ll run it another season and see how it looks.
Any snow left by you Clutchmaster? See the marked the lakes by Minocqua.Ok thanks Cdale, I have the 15 wide now also. So I guess I’ll run it another season and see how it looks.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
No snow in central WI at all.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
They open Oneida and Vilas tomorrow morning. Down here there’s thin snow. I went to dinner in manitowish waters and they have plenty of snow! Saw the groomer tonight heading up, gave me serious wood! Trails look to be decent north of minouqua.
