1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Somebody needs to introduce Artic Cat to constant tension hose clamps.
Put a $16000 price tag on a sled but build it with the cheapest crap you can find.
The chassis needs to catch up with the build quality of the Yamaha engine.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Wow can’t believe this. My buddy’s brand new AC had a problem last weekend similar to this but his hose actually had a cut in it. Dealer fixed it quickly. Is this a shared design component between AC and Yamaha? I’m pretty sure it is the same setup.
Pstn head
And if I might add gaskets and seals, and a real oil tank and a real chaincase.Somebody needs to introduce Artic Cat to constant tension hose clamps.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Got a small coolant leak. Noticed today when pulling sled off trailer. SURE enough right where Dan posted pics. Just over 3 k on sled. Noticed coolant dropped after COLD conditions last trip. First I saw a drop in coolant. Guys have coolant drops especially after COLD conditions they need to check clamps in the post here. Great find Dan and good post. I store my sled in heated garage and saw zero coolant leaks. But when sitting out or in trailer in COLD conditions it appears.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Even if you dont see coolant on floor, always reach up and grab right side of drive axle(between right driver/sprocket and tunnel.) But closer to driver. That is where I always had the coolant dripping down. So I tend to reach up there alot and see if I can feel coolant, as coolant is quite slick feeling.
Sucks that its so hard to get at.
Dan
Dan
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
Put sled outside today for 5 hrs in -21c,leaking from under tunnel by the rh driver again.I guess the dealer doing a pressure test last week in a warm shop on a room temp sled does not help them find leaks (said tech could not find any leaks)even when you give them pics of where leaking from.Is this just lazziness or what.Have extended warranty, I do not understand why they would not of taken it apart and checked for loose clamps.Time to take it to another dealer.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Take to a better dealer.......Put sled outside today for 5 hrs in -21c,leaking from under tunnel by the rh driver again.I guess the dealer doing a pressure test last week in a warm shop on a room temp sled does not help them find leaks (said tech could not find any leaks)even when you give them pics of where leaking from.Is this just lazziness or what.Have extended warranty, I do not understand why they would not of taken it apart and checked for loose clamps.Time to take it to another dealer.
But honestly, sometimes the only way to be sure something is done and done right, is to do it yourself. I have lived my life this way and there really is nothing I dont do myself. Might be the OCD, or might be the cheap in me...lol
Dan
rla1
- Jan 4, 2015
- saskatchewan
Took it in to diff dealer to find leak that is dripping from top of tunnel down onto rh driver.tech pressure tested it after sitting outside in cold, found leak but not from exchanger hose.Was leaking from bottom of thermostat housing running down hoses/wiring to top of tunnel area and then dripping down he said. Only way he found it was by removing overflow tank.Tightening clamp and replacing clamp did not help he had to cut 1/4 " off hose and reclamp to finally hold pressure and stop leak.Left it outside in -27c overnight checked in morning no leaks brought it back inside cold, pressure tested again all good.Hopefully this is fixed now and no more issues
deweydog
Just saw a post on another forum where 2 Sidewinders had cuts to the hoses, they believe from ice chunks. If true, then tightening clamps....putting a new hose...etc... will not cure the issue. Sounds like some type of shield would be needed if ice can get to it from the track.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I still find it hard to believe ICE cut through this hose. It takes so much to cut thru this hose with a BRAND NEW RAZOR which is ultra sharp.Just saw a post on another forum where 2 Sidewinders had cuts to the hoses, they believe from ice chunks. If true, then tightening clamps....putting a new hose...etc... will not cure the issue. Sounds like some type of shield would be needed if ice can get to it from the track.
I just think if this was the case, we would have seen many many of them happening....why is it just these two? The ice thing may or may not have happened, its a theory. While it surely can happen and it may have, it also could have been something else sharp that caused those sleds failures.
Not saying they are wrong or right. Just saying not to jump to conclusions. Surely something we all need to watch for, but an ENTIRELY DIFFERENT ISSUE then a sled like mine with a seep which was never even rode yet(0 miles).
Dan
RX1Jim
Has anyone else experienced the coolant leak from this hose? Has anyone come up with a design for a cover/protector for this hose? The "off-season" gives us plenty of time to resolve this problem.
Jim
Jim
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Jim
I noticed mine leaked last year. I never noticed it again after that. I did check it every now and then and it hasn't leaked since last season. If I do keep this sled I will do what Dan did and remove the fuel tank and tighten the hose. I will however wait to see if someone comes out with a guard to protect it first so I can install it at the same time.
Stormbringer
- Jun 5, 2018
- Valparaiso Indiana
- 18 sidewinder rtx 15 viper rtx
All I can say is O my God! You have got to be Kidding me!Now down to the header shroud....must remove the V-Clamp from header to pipe. This will allow you to slide upward the header shroud and out of the way, so you can get at the clamps.
There is heat foil over top of this hose, which is important as the header glows. I used a hair blower to heat up the glue on it and removed it. It loses its stickem abit, so when reinstalling I clamped it in with the bolt for shroud.
Dan
View attachment 134963 View attachment 134964 View attachment 134965 View attachment 134966 View attachment 134967 View attachment 134968 View attachment 134969 View attachment 134970 View attachment 134971 View attachment 134972 View attachment 134973 View attachment 134974 View attachment 134975 View attachment 134976 View attachment 134977 View attachment 134978 View attachment 134979 View attachment 134980 View attachment 134981
piskapo
- Feb 18, 2012
- Barrie
- 2014 Viper LTX-SE 240 Hurricane Turbo Kit
There is a new updated hose from Yamaha. They told me the reason is from the twist in the chassis.
Probably a combination of things. Do know need to keep up on all bolt and rivets in that whole area.There is a new updated hose from Yamaha. They told me the reason is from the twist in the chassis.
- 8K
