bleedyamaha
- Sep 28, 2013
- Northern Iowa
Hmmm How do you do that? Brake cleaner?has anyone checked for boost leaks yet .
sx7001
- Jun 28, 2003
- Sidewinder
krm, I think they forgot the turbo on your sled. And yes go with the biggest rollers you can get. Tighten that secondary up to 9-3 also then report back. It will scream!!!!!!! lol
Byam
slotted arm is good to reduce inside ski lift!I wonder if the slotted front arm is really necessary? I believe that is also a contributing factor in the limited transfer.
For more transfert XTX 141"is way better thanLTX 137"thats it...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
**sj**
Facts...this skid will transfer...but not over transfer like doo...
I'm betting yam has this clutching set up loose for prevention of belt issues...
run SMALLER roller for more belt squeeze...either add more twist to secondary spring...or better yet try stiffer secondary spring...
No sense seating the clutching yet if you are doing mods...
Cats are geared to get out first but won't mph like Sw unless turned up and run out of gear..even still sw ratio should better it...
buyrite01
What about the cat old purple spring?
Kevin
Remind me will the 8DN belt do anything for top speed or out of the hole?
krm
- Apr 22, 2016
- ny
larger roller will give more squeeze ,not smaller ,the ramp needs to be alittle more aggressive down low the larger roller will get it moving faster with less rpm .Facts...this skid will transfer...but not over transfer like doo...
DC5
Smaller roller will give more shifting force.larger roller will give more squeeze ,not smaller ,the ramp needs to be alittle more aggressive down low the larger roller will get it moving faster with less rpm .
krm
- Apr 22, 2016
- ny
you might have less rpm with a smaller roller that will make you think you have more squeeze as the rpm will be lower .but the larger roller will produce more squeeze as the ramp is more stood up keeping rpm up and shifting the sheaves .get a v max 4 kit from hauck ,it's the 1st thing he wants you to do as you can't shim the spider on a yamaha .we have on the v max 4s used thinner pieces in where the spider assy screws into the inner sheave to get the ramp closer to the roller .Smaller roller will give more shifting force.
buyrite01
we all need to work together to get this sled right OR your cat friends are not gone to let you here the end of it! I have 2 friends with new cats and me with SW.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Sounds like the hole shot and mid range clutching need some tweaks.. The top end will be good especially with some miles on the motor. Yes I just came over from Cat!
- 149K
- 50K
- 39K
