**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
1 oookm whit thunder 14.8 primary roller and the bushing are gone:-(..... only 2 ride, and way to much play.... They are pretty expensive here in Canada
The stock bushing is coming of normaly clockwise, but whit them glued they are way more durable than the thunder, at lest for me!
I am gona shop for 3vl this summer and get rit of my Yamaha snow flap.....
YAMAHA Clutch SUCK
what weights and how much gram you run?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Damn that sucks. And not good to hear.
Did you contact Lonn? Maybe he will do something for you? I was under impression these rollers from TP will be a one time purchase and last life of sled.
Dan
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
GForce S2 at 84gr YWY. cam 41-37.what weights and how much gram you run?
Now i am doing some testing for GForce on their new primary roller 16mm. They are holding up 1200km whit them now.
Different setting Gforce S2 80,5gr. YWY. Cam 45 straight. Realy good setup for parts durability fuel autonomy but a little lack of snap down low for my type of ride....
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Seems like you could still run your progressive helix with good results tho
- Apr 14, 2003
- Hessel, Michigan
View attachment 139458 View attachment 139459 Hi rockerdan. No i didn't contact Loan you think i should? Look at the one in the middle, the weight was about to flip the roller and babooooummmm.......:-/
Byam, something is not right in this picture.....the bushings should all be black like the top roller.
I am going to call Lonn at Thunder Products and make sure he knows this issue.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Dan. I don’t think any roller is going to last the life of the sled at these hp’s. With that I have a set in my viper turbo with 3500 miles 190 hp and 2500 miles stock hp. Also a set in my winder at 275 hp. 800 miles and are still good. This is with thunder Products weights. Weights play a huge role in how long rollers last.Damn that sucks. And not good to hear.
Dan
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Those are "fiber"type bushing and like all roller the bushing is coming out clockwise. When the roller can't turn the bushing worn extremely fast.
The one that looks correct in the picture was seized also (bushing out clockwise)
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
The 14.5 mm rollers obviously don’t work. I was at my dealer, he was saying for 2019 Yamaha is putting larger rollers in the winders, and a different secondary spring that is supposed to make it backshift and keep up with the primary better.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
After talking whit M Lonn (gentlemen) he asked me to semd him back the roller....Byam, something is not right in this picture.....the bushings should all be black like the top roller.
That's what i received
Thanks nos-pro for the follow up
- Apr 14, 2003
- Hessel, Michigan
Fleecer
- Jun 13, 2014
- 2019 SRX
Any performance gain/loss in using bigger roller......say 16.0 vs 14.5????
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Bigger rollers apply less shift force, so might say a performance loss. One can shim the spider to get it back though too.
I just don't see a larger roller helping this bushing problem. They all have the same size bushing and it just wears out fast with the weight and harmonics of this thing. Now if you had a six arm clutch that would disperse the load across 6 rollers rather than just three
