Fuel Shut-Offs
99SRX700
Southern New Hampshire
I have decided to install a fuel shut off valve on my 05 RX-1 after hearing all the stories about trailering with a full tank. My question is where do I get them and where do I install them? Can I get them through the dealer, and where in the fuel lines do I install them?
While you are cutting rubber lines, you might as well install a coolant shut-off valve to the carb heaters too. I used a Ski-Doo valve on this line (expensive thought).
I thougt the carb heaters were automatic?(shut off after certain temp) is this wrong? Jay
So the electric heaters don't shut off the coolant? Talk to me about coolant shut offs! Jay
The carbs are heated 2 ways; Electrically for instant heat and by engine coolant. Once the engine gets to temp the electric heaters are turned off while the coolant is still pumped. Many have installed a shutoff on the coolant line on the left side as it leaves the carbs. This helps out performance a little on very warm days. It also helps warm start conditions.
