Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
This is what I used been on my sled for over 4 yrs and I use this at work for surfaces that double sided tape has issues sticking to works awesome.Who knows?!?! I use that "I lock" grade. Seemingly uses a pretty stringent adhesive.
But I'll do as you, clean it, heat it and stick it....see how it goes.
I'm pretty sure I've seen other posts here in the past where guys are sticking it right to that cover, but never followed up to see how it's going.
I get what you are saying now...yes that would definitely work as well.Look again .....the flasher is OBD2 the extension cable goes in between the flasher and the GAP conversion cable to CAT diagnostic connector
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
In following with no1b4me's instructions, I suppose I'll mount my flasher to reverse actuator cover. Wish me luck.Mounting on actuator cover ,hit it with 400 grit ,wipe clean with alcohol and apply velcro...works everytime ....aluminum cover is too smooth to get a good adhesion bite ...
I wish there was a quick, easy and safer location to mount dragy magnet. I suppose I'll just throw it on the hood. It just sucks....oh well.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I've been running my dragy on the hood next to the cluster for a couple years. It doesn't fly off lol.In following with no1b4me's instructions, I suppose I'll mount my flasher to brake actuator cover. Wish me luck.
Doc Harley
- Oct 17, 2016
- Here & there
DMC, did you post a pic in here?I've been running my dragy on the hood next to the cluster for a couple years. It doesn't fly off lol.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I found this today after I talked with Dave at Hurricane
www.maxcelerationracing.com
Flasher Fortress - Flash Communicator Protection | Maxceleration Racing
The Flasher Fortress provides protection for your valuable GAP flash communicator used by Turbo Dynamics and Hurricane. It protects your flasher while you have it attached to your 2017+ Sidewinder or Thundercat to use it for data logging, launch control, multiple tunes, etc. - Rugged flame...
I ordered that last week and I should be receiving it shortly. Since my current flasher's plastic is damaged from heat it will be good to have it enclosed and protected better.I found this today after I talked with Dave at Hurricane
The Flasher Fortress provides protection for your valuable GAP flash communicator used by Turbo Dynamics and Hurricane. It protects your flasher while you have it attached to your 2017+ Sidewinder or Thundercat to use it for data logging, launch control, multiple tunes, etc. - Rugged flame...www.maxcelerationracing.com
DMCTurbo
- Nov 12, 2005
Pic of what?DMC, did you post a pic in here?
Doc Harley
- Oct 17, 2016
- Here & there
The exact location of magnet. It's ok if you cant. It's just as I recall, everything overnight gets iced up and Frozen. Ice droplets everywhere. Just can't think of a good clean spot. I'll do something.Pic of what?
Doc Harley
- Oct 17, 2016
- Here & there
I'll just mount it on the console and use my cover overnight.
I just mount mine on the council and put it in my handlebar bag when not in use....a lot of people just carry them in their pocket.I'll just mount it on the console and use my cover overnight.
Doc Harley
- Oct 17, 2016
- Here & there
I didn't think it would adhere to that porous plastic. Thank youI just mount mine on the council and put it in my handlebar bag when not in use....a lot of people just carry them in their pocket.
- 10K
- 8K
- 44K
