STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
That time of year again, waiting for snow and spending money.
Has anyone used the GAP ram air on a stock muffler tune? I can see where it has been used on header and PM tunes but not a lot on SM tunes.
Is it worth it? Will it work WITHOUT a closed loop upgrade? Do you need to inform the tuner of it before install?
They are priced between $300 and $214.
I already have the Hurricane intake tube and was wondering if this thing would help at all.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I installed one a season or two ago, and honestly I dont know what to believe.
IMHO, someone would have to get IAT's of a gap ram air vs a cold air kit to verify any usefulness. Possibly the need for more fuel pressure to maintain a specific afr. I think it's just a cool novelty.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
@ 10psi of boost and running at 8500 rpm, the 998 is pulling air in at about 75MPH. That is what it takes to keep the engine fed with sufficient airflow. If the intake were already ideal, thats also the speed you would have to overcome to have the ram air intake have any (theoretical) noticeable effect. The stock intake however, not ideal. It is long, convoluted, and has several pinch points in the intake ducts under the hood (creating turbulence). The biggest impact of the ram air intake would come from bypassing the molded air ducts built into the hood. The GAP intake is ideal at creating some small amounts of intake efficiency while remaining relatively stealthy if you care about that but ... it still isn't an ideal intake due to the bend in airflow caused by still using the stock airbox. An ideal intake would be both ram air, have a smooth transition from greatest diameter to intake pipe size, and would have a smooth radius bend to reduce turbulence in the intake air stream.
The benefit is the colder charge of air. I don't believe there is a true ram effect but the airbox is getting packed with cold air instead of a stock airbox or Cold air intake inside the engine compartment drawing warm air. They absolutely work
Turboflash
- Mar 18, 2019
- Southern MN
It has been previously stated and proven (via temp probes) that the stock hood actually does a pretty good job of ducting cold air into airbox, compared to using a cai setup which can pull warm underhood air into inlet tube (at low speeds especially).
Agreed on the CAI under hood TF. They do a nice job of sucking in belt dust, but if it is not pulling external air it's useless.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The GAP ram air actually takes it from outside the hood.It has been previously stated and proven (via temp probes) that the stock hood actually does a pretty good job of ducting cold air into airbox, compared to using a cai setup which can pull warm underhood air into inlet tube (at low speeds especially).
Turboflash
- Mar 18, 2019
- Southern MN
Yes. I was more referring to "cold air intakes" which do pull underhood air especially at slow speeds.The GAP ram air actually takes it from outside the hood.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Data logging.
AFR
IAT
More fuel pressure
The Need for more weight in primary clutch to run same rpm
All methods of knowing if it makes a difference.
AFR
IAT
More fuel pressure
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Improving the intercooler to lower intake air temp and the evacuation of hot air from under the hood may do more for performance overall than the ram air.
The 998 intercooler is not as efficient as the one on the old 1100 turbo. It had a better intercooler.
Getting the heat away from the clutches helps lower belt temps.
When I built my old 1100 these were things I noted. If you spend more time on the trail's verses lake racing, not sure the ram air will be useful due to the heat soak under the hood. Testing with data is the only way to find out.
- 10K
