yamahahaapex
Well I seen this was on the second page today and after finishing reading all 37 pages this week, I've went as far as grabbing the parts and then changing my mind again. I think Im going to wait on this one before attempting rocker dan's "T" mod. I've got an '18 xtx with 200miles and I've heard a few winders having the issue with the oil tank seal and sludge build up in the intercooler.
I do have 4 years of warranty but downtime is hard to replace, especially when its time to ride. The "T" mod from rockerdan would fit my style especially as the most snow we see around here is about 6' annually and rolling it over or on it's side is not going to happen.
We will see how the 18/19 season goes as stock and check back in on this later.
Very good read!
Very good read!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
T Mod will work to relieve pressure, and I just did it for a temporary fix last yr. Shortly after I removed the entire ROV and installed a new hose/loop, as I posted several places. Works great.
Dan
Dan
sledheadgeorge
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Exactly what I did last year. No problems and the air intake is clean. Put 60 km today and it's goodI'm in. With the 5/8 " line. Only thing I want in my turbo is air. If this motor was N/A like the Apex I wouldn't mind. Might splice in a rollover valve down the road.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
What did you all use to plug the intake side? Sorry if this has been posted already but couldn't find it.
1/2 " i.d. rubber cap. You can find these at any hardware or automotive store.What did you all use to plug the intake side? Sorry if this has been posted already but couldn't find it.
SideHogger
- Apr 16, 2016
- upstate ny
Thanks fat chance. Gotta Love this frickin forum!
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Ok had one freeze this weekend. -30. Why not take out the valve Replace with plastic nipple. We flatlanders don’t roll over. If we do more problems than oil !
gsxr
- Feb 24, 2006
- 2023 SRX
Ok this is what I was wondering....so the pressure within the oil system needs to have a release, and currently its done thru the valve and intake tract.
gsxr
- Feb 24, 2006
- 2023 SRX
Simply clean and tig oil tank to chain case. No need to take apart. No deal to leak. Remove BOV plastic nipple in its place. Done
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Mine is working flawless for ultra cold temps, need to cut the end correctly, never froze yet.Simply clean and tig oil tank to chain case. No need to take apart. No deal to leak. Remove BOV plastic nipple in its place. Done
Not sure Id want to weld the tank shut for good, lots of stuff in there that I like to make sure isnt clogged and is in tact.
Dan
number1kyster
**sj**
seems like a regular maintenance of the outlet as shown on right pic above, hose and valve is a must...a heat gun before riding might be a good idea...
for those that think who cares if I roll over and lose some oil...you can easily remove piston and spring from valve and make it straight through (sans roll over protection)
apexboyz08ltx15se
- Oct 17, 2014
- Michigan
- 2018 sidewinder 50th apexse2015
- Michigan
That was my cousin Sled. 17 winder in the picture that number 1 kyster posted. We was in Houghton/Hancock. Mi. Over the weekend. The sled Gage Said -9 when we stared it that morning (Saturday ). Blow the oil tank seal before fully warmed up. We took it apart and that’s what we found. I. Have a 50th rtx winder. My rov. Froze up while riding on the way to Houghton and blow the seal. Not only after spending a lot of money on the sled and trips. This design is uncalled for. This is my first post I usually just read. The 17. Has 1700 miles. Mine. Has 1500 . The other.thing I don’t like other then oil on the intake tract. The the amount of WATER / CONDENSATION that gets into the oil.
apexboyz08ltx15se
- Oct 17, 2014
- Michigan
- Michigan
I guess I should have also added. Both of these sled where bought new. Always stored in a heated garage trailered in a enclosed trailer any and all maintance done by the book. Etc etc
- 46K
