Mtoguy
And check to see if your solenoid was replaced at same time starter was. This problem with magnets has been going on since first 4 stroke Yamahas. Starter runs on after motor is running heats up starter and magnets come unglued if you don't catch it in time.
- Apr 14, 2003
- Hessel, Michigan
Might be why we have never had the kickback as we always run 91+ octane.
It's not a 91+ octane issue, it happened to Shagman who runs 91+ and some race fuel. Happened to a couple more that run 91+
Only thing why you don't have it is because your higher altitude than what we are.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Both my 14 viper and my wife's zr 7000 ran only 87 all last season and we haven't had a single kick back!Might be why we have never had the kickback as we always run 91+ octane.
One thing I noticed was in warmer temperatures 0 to +15 degrees Celsius (our last run or two)my wife's sled would be a little harder to start. Most of our riding is usually between -10 to -25 degrees Celsius and they both start right up!
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
I've had my share octane is a non factor. I've run 110 all summer and I've had 2 since replacing my starter in spring.Might be why we have never had the kickback as we always run 91+ octane.
canadianhunter
I installed the starter saver from ROCK, hoping to prevent a burnout do to worn wires etc.Mtoguy
Studroes144
- Oct 30, 2013
I think the best thing people can do to hopefully prevent it is battery maintenance, I just bought a battery tender and am gonna just have the quick hook up on it and put it on once a week or so in the winter time, the faster the engine turns over the less chance of kickback
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
After 27 pages of this topic, I can say that you guys are really starting to worry me. But I'll just throw this out there ... I have a 2015 RTX that I put about 2500 miles on last season. Knock on wood - I never experienced the kickback.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Are you running the 14 or 15 flash on those sleds?
If its the 14 flash stick with it. I put about 1200 miles on the sled and I had the hard start when warm issue like you. but never had a kickback. I reflashed it and put on about 4-500 miles and i have had 1 kickback
stingray719
Yep what he said. Also, a weak battery can cause starter/magnet issues as odd as that sounds.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I called Yamaha had office today and they are working on a new flash, they said that if they got it fixed that it should be out around when the one came out last year.
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
It's the 15 re flash never had a kick back with the original flash . My sled stays in a heated garage after every ride and hooked up to my battery tender !!! Dealer also told me new flash coming soon .
fc8464
- Aug 4, 2014
- Fairbanks, Alaska
- 09 Summit
15 Viper MTX 153 blue/white
Dont sound odd at all, a weak battery or poor conections causes voltage to drop when cranking. Low voltage means higher amperage and that is what burns up internals. FredYep what he said. Also, a weak battery can cause starter/magnet issues as odd as that sounds.
I have often thought about the battery cables being so long also. Really important to keep connections clean and tight. Mine turns over very fast even at -35f but if I had issues bigger cables like welding cable would surely help.
Studroes144
- Oct 30, 2013
That's one thing that my dealer has been saying now since mine went last winter, they think a major cause is a combination between low batteries and longer cables from the battery to the starter in comparison to the other yanahas where the batteries are right there under the hood instead of in back under the seat.
Dmarks
- Jan 9, 2014
As far as the new flash goes, I know that they held the dealer meeting last weekend so I tried calling my dealer but the guy who attended wasn't there to ask so start calling. Oh this was a Canadian dealer meetingThat's one thing that my dealer has been saying now since mine went last winter, they think a major cause is a combination between low batteries and longer cables from the battery to the starter in comparison to the other yanahas where the batteries are right there under the hood instead of in back under the seat.
