Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Well it's over. Rummage bought a new 850. The challenge is gone. I ran a few in Wisconsin and the UP. Embarrassing, kinda felt bad for them.
Like a professional fighter going to the grade school for a match. It would last for a few seconds with the little 2nd grader flailing around for 500
feet or so then Game Over. Not even in the same zip code. Thought maybe the rod bolts broke and the engine exploded or something locked up. Sad just Sad.......
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Wtf? Did rummage have some type of mental breakdown? What was he thinking?Well it's over. Rummage bought a new 850. The challenge is gone. I ran a few in Wisconsin and the UP. Embarrassing, kinda felt bad for them.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Not sure. I was shocked. Kinda like when someone you have known for a long time comes out of the closet.Wtf? Did rummage have some type of mental breakdown? What was he thinking?
Sledhunter
- Mar 20, 2016
- Indiana
- Sidewinder
arctic cat couldn’t. You need to buy a fourth wheel kit cause the tri-hubs are only good for a 1000 miles then boom your left broke down on the trail. Replace the skis with pilots to make them turn. Pilots come from the factory on doo’s. Bolts falling out of turbos, chaincase/engine oil leaks. Shagnos just had an oil leak bigger than the Exxon Valdez spill. As for coming out of the closet shagnos knows all about that! The truth will come out, stay tuned!
Want me to start collecting Blown Doo belts and make a nest for your Doog with the fragments? This is Racing section but talk racing and dont forget where you are. Last warning.View attachment 137800 Just spoke with rummage, says he made the right choice! As a doo and Yamaha owner I have to agree. Those Yamaha shitgrinders/arctic scrap junk being passed off as the next best thing to hit the sled industry just ain’t what they’re cracked up to be. Sure they’re fast but that’s it. 500.00 clutch kits to correct spring coil bind, secondary rollers that go flat in the 200 miles, junk! You have to spend tons of money to fix the #*$&@ arctic cat couldn’t. You need to buy a fourth wheel kit cause the tri-hubs are only good for a 1000 miles then boom your left broke down on the trail. Replace the skis with pilots to make them turn. Pilots come from the factory on doo’s. Bolts falling out of turbos, chaincase/engine oil leaks. Shagnos just had an oil leak bigger than the Exxon Valdez spill. As for coming out of the closet shagnos knows all about that! The truth will come out, stay tuned!
Sledhunter
- Mar 20, 2016
- Indiana
- Sidewinder
Please do! I can add those fragments to Mine and Shagnos sidewinder blown belt fragments and make a big comfy nest! Fyi over 9k miles on doo 800’s never blew a belt.Want me to start collecting Blown Doo belts and make a nest for your Doog with the fragments? This is Racing section but talk racing and dont forget where you are. Last warning.
Lesson learned.
You either arent stock,change belts every 90+mph run or you just putt along. Either way unless you know Shagnos personally you are a Troll.View attachment 137803 View attachment 137802 View attachment 137802
Lesson learned.
Sledhunter
- Mar 20, 2016
- Indiana
- Sidewinder
What’s with the name calling? Troll? Ya I know Shagnos personally, know him well. I’m not as awesome as shagnos but I do speak the truth..........
And no I don’t putt putt around.
OK did not know you knew him. Sorry. Like I said either you Putt Putt or you are not stock. Stock 800's blow belts and so do the 850's when I am riding with or on them. That is a fact.What’s with the name calling? Troll? Ya I know Shagnos personally, know him well. I’m not as awesome as shagnos but I do speak the truth..........
I have read enough.. I think its time to kill this worthless thread.
- Status
- 11K
