REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I used most of the provided packet no where near enough in the packet to fill the entire cavity. So I guess the idea of filling it completely is not the intentWhat’s the verdict on grease? Half the package? Or all of it?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
I used half the package. I have videos of before and after but can’t seem to get them uploaded ! Noticeable difference though, will see how long it lasts. Not 100% gone, but improved
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I would think the more you put in the longer it will last. I was going to use it all and then add to it honestly, but I'm still working on the rest of the machine to get it prepared and not real worried about the stub shaft yet.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I was wondering, what happens to that grease in the cavity?I used most of the provided packet no where near enough in the packet to fill the entire cavity. So I guess the idea of filling it completely is not the intent
Did you happen to take a peak at your coolant temperature b4 you shut the sled off?I used half the package. I have videos of before and after but can’t seem to get them uploaded ! Noticeable difference though, will see how long it lasts. Not 100% gone, but improved
Turboflash
- Mar 18, 2019
- Southern MN
Gradually, eventually it ends up mixed into engine oil. It can't escape - outer bearing is sealed.I was wondering, what happens to that grease in the cavity?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Overtime the grease will get beat up - oil will likely work its way in, diluting the grease over time.I was wondering, what happens to that grease in the cavity?
When i have serviced this bearing I would pack the splines with heavy grease before reinserting the assembly. It helped dampen the noise and keep the metallic sound down - for a bit. This kit with the O ring may hold the grease for quite awhile. But i bet after a season it would be pretty mutilated.
I am interested in posts after a few thousand km.
MS
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How did your phone call go?Nooo!!! Haha. I did the same. Let me give a call to Tapp on Monday and see why, the world's leading clutch company for the 998t would include a specified amount of Grease for the ability to grease it twice, and yet not include that in their very specific instructions. (Long sentence)
While I agree it was a lot. There is a void inside the hub where all the extra grease gets pushed, obviously opposite of the seal.
Either call them yourself or trust my words. I make a solid bet Tapp will thinks it's ok, either way. Meaning no damage will be done.
Same as mine i bet.
Doc Harley
- Oct 17, 2016
- Here & there
Tim, based on group recommendations I decided not to make that call.How did your phone call go?
Same as mine i bet.
Looking at the facts, even if it does get overfilled I don't see any harm coming from it.
What happened with you? Lol.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I am waiting this one out. The clutch rattle has never bothered me.
Why didn't yamaha just drill a hole in the crank to pump pressurized oil into the spline?
Doc Harley
- Oct 17, 2016
- Here & there
I'm like you, never even gave the noise a second thought. But now after installing the knockout kit, it's kinda like owning a new sled. I'm somewhat amazed.I am waiting this one out. The clutch rattle has never bothered me.
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
I just did this kit on my xtx and srx. I wasn’t amazed by any means. It helped stop some noise but seems to have made the clutch noise more pronounced for me. Probably just eliminated enough other mechanical noise to allow the clutch noise to come through more. That’s my experience anyways.I'm like you, never even gave the noise a second thought. But now after installing the knockout kit, it's kinda like owning a new sled. I'm somewhat amazed.
HABS 1
- Oct 22, 2015
- corunna,ontario
curious how much grease u put in? half pac or whole?I just did this kit on my xtx and srx. I wasn’t amazed by any means. It helped stop some noise but seems to have made the clutch noise more pronounced for me. Probably just eliminated enough other mechanical noise to allow the clutch noise to come through more. That’s my experience anyways.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
I don't think you want to overfill with grease. You could be pushing on the crank some until it finds its way out? I have a kit and have not looked closely at this yet and could be wrong.Tim, based on group recommendations I decided not to make that call.
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
I used most of the package it came with. I won’t be saving the little bag of what’s left, maybe 5%.curious how much grease u put in? half pac or whole?
HABS 1
- Oct 22, 2015
- corunna,ontario
im gonna do same, use most the package, got the shaft on bench... i mean even if it hepls it cheap n like half hr of work!I used most of the package it came with. I won’t be saving the little bag of what’s left, maybe 5%.
- 49K
- 54K
