Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Deleted, inaccurate information
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Looks like a horror show in there.I'll get one going tomorrow. I'll use some extreme pressure grease I have. Nothing in this world can break it down. Nasty!!!
Valvoline Crimson....
Note: yes earthling there is better, but this is sitting on my bench. Hahaha
Doc Harley
- Oct 17, 2016
- Here & there
Bud.... I think I discovered its weakness. After talking with another person of interest it was discovered that it doesn't have a temperature rating. Lol.Looks like a horror show in there.
Damn you, earthling!!! Lol.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Systematically Selecting the Best Grease For Equipment Reliability
Heavy-duty greases are the lubricant of choice for many industries, especially those with harsh environments and applications. By selecting the appropriate grease that matches your unique needs, your grease can help your team and site operate at maximum efficiency while keeping your grease and...
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
What’s wrong with the grease that comes with the kit ?
There is some pressure but if people start using their own brand of grease and get carried away it could be difficult
This is the stuff I've been using for a few years. Holds up great in the bearings
Doc Harley
- Oct 17, 2016
- Here & there
Deleted, as inaccurate info
The Hurricane noise reduction shaft I installed, before they came out with their current collar, virtually eliminated all the clutch noise with the stock SW primary but I have been using an Apex primary for a few years now and it is a bit noisier although nothing like stock.
Depending on reviews I may order a Knockout ring as well and try it in the Hurricane shaft...if it fits.
I will be waiting for reviews....
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I wouldnt overthink the grease too much. Regardless of how good you think your grease is it will not last forever. You wont know what intervals it need’s disassembly till their some miles on these kits but it is not a one and done kit, cant be. It may be once a season, every oil change or more often. Really who cares though, it takes minutes to pull apart and repack and you have a sled that doesnt sound like a 7.3 powerstroke for a small investment and a little grease. Use the grease that comes with the kit and when you run out source something else or call Dave at tapp and get more.
Doc Harley
- Oct 17, 2016
- Here & there
I found the PI sheet for Valvoline Crimson grease. Sadly, Its limited temperature range of effectiveness would not meet the temperature conditions of my intended use. 25° - 250°I wouldnt overthink the grease too much. Regardless of how good you think your grease is it will not last forever. You wont know what intervals it need’s disassembly till their some miles on these kits but it is not a one and done kit, cant be. It may be once a season, every oil change or more often. Really who cares though, it takes minutes to pull apart and repack and you have a sled that doesnt sound like a 7.3 powerstroke for a small investment and a little grease. Use the grease that comes with the kit and when you run out source something else or call Dave at tapp and get more.
So ill have to fall back on Lucas Red & Tacky or like product for general maintenance.
Justin, while I appreciate the desire to stick with what ever Tapp recommends, I like to use what's been working and have the ability to use on other general maintenance. The "one tube works on everything" approach.
Doc Harley
- Oct 17, 2016
- Here & there
OMG! Take a wild guess on who forgot the torque down their primary? It basically felt like there was 20 foot pounds on it.
Thank God for Tapp industries and they're knockout kit!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
omg that could have been interesting!OMG! Take a wild guess on who forgot the torque down their primary? It basically felt like there was 20 foot pounds on it.
Thank God for Tapp industries and they're knockout kit!View attachment 174375
Is the final torque value still 43ft/lbs? I thought i had read it was advised to go with more?
Doc Harley
- Oct 17, 2016
- Here & there
I believe TD recommendations 110/60 with their tunes.omg that could have been interesting!
Doc Harley
- Oct 17, 2016
- Here & there
It's the little things that are so helpful.
Thanks, Bob!
Thanks, Bob!
SW Primary bolt Torque:omg that could have been interesting!
TD recommendations:
1st 110 ft/lbs
2nd 60 ft/lbs
Yamaha Specs:
1st 108 ft/lbs
2nd 43 ft/lbs
Apex Primary bolt Torque:
Yamaha specs:
1st 85 ft/lbs
2nd 43 ft/lbs
So begs the question...when using an Apex clutch on a SW which torque specs should you use?
I personally stayed with the SW clutch torque specs with Apex clutch on my SW but I had a 300++ hp Apex that I ran Apex clutch torque specs on without any issues.
- 51K
- 55K
