rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
![](/styles/donate.gif)
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
$125us TyI replaced my driveshaft, rotor, bearing and put in the saver. Got this rotor from hurricane..cheaper then oem. No miles on it yet. $168cdn
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
My 18 50th LE also came with OEM light weight rotor but that hurricane rotor is bad A$$.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Just a question what’s the down side of reusing that rotor. It floats in place does it not
Doc Harley
- Oct 17, 2016
- Here & there
Definitely! I'm making a last minute judgement call to reuse it. Just being honest.Just a question what’s the down side of reusing that rotor. It floats in place does it not
Turboflash
- Mar 18, 2019
- Southern MN
If you got that all apart with the BOP wedge in, and didn't have to loosen it, it wasn't tight enough - didn't expand enough to prevent shaft from spinning in bearing. Shaft is badly worn, bearing is badly worn. You can also see on inside of rotor that it was spinning on stationery bearing race. Might be able to make it work with BOP new shaft saver product (https://barnofparts.com/apps/webstore/products/show/8256852?siteId=134334799&locale=en-US).Yes....bearing is loose on shaft.
If you don't have press, then try heating caliper housing with torch around bearing. Most say it will drop out (remove snap ring duh). Install new BOP bearing by putting bearing in freezer for a few hours, heat caliper housing with torch, drop frozen bearing in. Should drop right in.
Be sure to bleed brakes.
Good luck!
Turboflash
- Mar 18, 2019
- Southern MN
It'll be fine to re-use. Brake caliper pads keep rotor centered anyway.Just a question what’s the down side of reusing that rotor. It floats in place does it not
Doc Harley
- Oct 17, 2016
- Here & there
In respect to axle saver, I didn't install it until 800 miles ago (3,000) So I'm pretty sure Everything had plenty of wear on it. So yes I torqued it to 30' lbs And I probably should have torqued to 45-50' lbs. It was probably too late regardless. I understand all your instructions and will proceed As instructed, with new Drive axle solution from BOP , etc. The only thing I don't understand is why your bringing up bleeding the breaks. I wasn't going to open anything up. please advise......JoeIf you got that all apart with the BOP wedge in, and didn't have to loosen it, it wasn't tight enough - didn't expand enough to prevent shaft from spinning in bearing. Shaft is badly worn, bearing is badly worn. You can also see on inside of rotor that it was spinning on stationery bearing race. Might be able to make it work with BOP new shaft saver product (https://barnofparts.com/apps/webstore/products/show/8256852?siteId=134334799&locale=en-US).
Good luck!
Mototown
Weld the shaft , buy a light weight rotor
Doc Harley
- Oct 17, 2016
- Here & there
It's the season opener & I'm ready to ride. Can't afford the time, at this point.
Going to put some faith into BOP repair.
Will reevaluate in the summer. Or sooner if there's failure.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Just a guess but maybe after heating the caliper they recommend bleeding it to remove any air if any..In respect to axle saver, I didn't install it until 800 miles ago (3,000) So I'm pretty sure Everything had plenty of wear on it. So yes I torqued it to 30' lbs And I probably should have torqued to 45-50' lbs. It was probably too late regardless. I understand all your instructions and will proceed As instructed, with new Drive axle solution from BOP , etc. The only thing I don't understand is why you’re bringing up bleeding the breaks. I wasn't going to open anything up. please advise......Joe
I take out mine every year to clean inspect and regrease without any heat, once the circlip is removed that holds the bearing in the caliper i use a socket that fits inside the caliper and catches the bearing, on the side of the clip I made up a rig that only catches the caliper shaped like a U with a hole in the centre, put the bolt through the socket and through the U shape bracket and tighten a nut on and the bearing comes right out.
Sorry I don’t have the puller with me to post a pic.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, I wasn't sure. I have a mighty vac/bleeder. And see what if anything comes of it.Just a guess but maybe after heating the caliper they recommend bleeding it to remove any air if any..
I do have a heat gun I was planning to use to heat up caliper. I'll try it, and see what's what. Got my snub shaft housing over 200°!
I think , if measured correctly the I.d is like 1.625". I'll get something to work.
Thanks, WinderfFab
Turboflash
- Mar 18, 2019
- Southern MN
Once you have new bearing, you might not be able to assemble the whole assy together. You might have to split caliper. If so, you'll have to bleed it. If not, then perhaps not. Not a bad thing to just check.In respect to axle saver, I didn't install it until 800 miles ago (3,000) So I'm pretty sure Everything had plenty of wear on it. So yes I torqued it to 30' lbs And I probably should have torqued to 45-50' lbs. It was probably too late regardless. I understand all your instructions and will proceed As instructed, with new Drive axle solution from BOP , etc. The only thing I don't understand is why your bringing up bleeding the breaks. I wasn't going to open anything up. please advise......Joe
Doc Harley
- Oct 17, 2016
- Here & there
Lol...it's funny you should mention that. Just before I grabbed my phone I was thinking along those lines.Once you have new bearing, you might not be able to assemble the whole assy together. You might have to split caliper. If so, you'll have to bleed it. If not, then perhaps not. Not a bad thing to just check.
Always something.....
Doc Harley
- Oct 17, 2016
- Here & there
I'm including the dimensions for bearing and shaft to try and figure out which one's more torn up. As I'm thinking maybe I can get away with a bearing. Idk!!! .017 clearance (this figure is with zero torque on shaft saver)
Shaft
Bearing
Shaft
Bearing
- 39K
