theewarrior
We have pretty much the same set up
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I wonder if something has changed with Yamaha roller material that is used on newer sleds. I have just over 5K miles on stock 15.6mm rollers on MCX Nytro 270 with 86 grams weights and just went through my clutches. Without a question they are in perfect shape with minimal if any wear on the bushings. Looking at other posts Tarzan is successfully running a Nytro primary on his 375Hp Sidewinder and has not mentioned of any issues.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Yes, the Sidewinder clutch has changed. The SW clutch has a larger diameter for the weight hole and roller location. This was done by Yamaha to put more force to grab the belt....hence why it is on the Sidewinders and not the Vipers.
The rollers are getting pounded now with more force put to them. The previous Yamaha primary clutch (Viper, Apex, RX1, Nytro) on the Sidewinders running huge hpr does not smash the roller bushing like the Sidewinder clutch does. And having large, heavy and flat profile weights make it more common for the roller to go out than the more aggressive, curved weights that use less weight to achieve the same goal which is performance, belt grab and longevity. This is why we have changed back to the previous style primary and also a billet aftermarket primary on our own sleds.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Terry.....What is the difference from Apex primary to Winder as far as Overdrive. How much do we lose? Also, do you feel the belt is grabbed hard enough with the Apex primary with 270+HP?Yes, the Sidewinder clutch has changed. The SW clutch has a larger diameter for the weight hole and roller location. This was done by Yamaha to put more force to grab the belt....hence why it is on the Sidewinders and not the Vipers.
I will add, that my Winder primary with your TP rollers is doing well now with over 4000miles on them and 2700miles now on same belt. I feel like I don't want to sell her!!!
Dan
Mototown
- Sep 11, 2018
- Apex 40 th
Ran these duralon bushings in my 14.5 rollers with cat green set at 9-1 for 700 miles at 290hp in upper Michigan this weekend no problems . Stock bushings in sidewinder wouldn’t have made it 200 miles before . Would recommend it to anyone having bushing movement problems.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
+1. Also the duralon bushings are more quiet.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Dan
Dan, Great to hear our rollers are doing well
The Apex primary is losing a little overdrive compared to the SW primary. It's not a whole lot. How much? Depends on the power of the sled and snow conditions.
The question is....do you machine the Apex primary clutch or not? For those who want all the mph, I would say definitely machine for overdrive. The sleds we have machined for overdrive are seeing awesome mph, even with stock gearing.
Example, 290 hpr BTX SW running the Viper/Apex primary (Not Machined) with 24/50 gearing was 110mph no problem on trail. 141 XTX running 270 hpr with 21/41 gearing with Viper/Apex primary (which is machined) for overdrive was 128mph where 119mph would have probably been the limit if not machined.
I took a couple pics to compare the fixed sheave diameter between the Apex and Sidewinder primarys...they are the same diameter. The second pictures shows the Apex fixed sheave overlaying the sidewinder fixed sheave.
As stated by the experts the diameter increase is only on the moveable sheave.
How much material are you removing from the Apex sheaves for overdrive?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
For me, I simply used to idle my apex, and take a file to bottom of sheaves...did not have to remove much at the bottom at all to get belt to come to top.How much material are you removing from the Apex sheaves for overdrive?
Dan
Dan
Years ago I removed .020" from both sheaves of a VMAX4 clutch by using varying grades of wet/dry emery paper on a flat surface, then I narrowed the lock collars on a belt sander...lol...bush league but it it seem to work well and had no failure issues.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Rule of thumb is not to go more than .030" per side.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
View attachment 147691 View attachment 147692
The difference in diameter is another reason why we have switched back to the previous style Yamaha primary.
Great thanks!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
What does a stock Apex clutch cost these days? I assume weights and rollers and springs are all same fitment between the two? So it just bolts right on Winder? Is the offset gonna be same as how we have setup the Winder currently?
Dan
Dan
- 23K
