Here.16+ 137 Cat,Sidewinder and Viper spring (2704-026,7)is not shown in this pic. Goes from lighter to heavier. Cat #'s 1704-576,7 are the 14+129" stock springs. Looks like the silver lightest one is not available anymore. Chart is current.
Spring Chart
Old chart
Spring Chart
Old chart
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I know exactly what I'm going to do to my Winder as far as transfer goes. I'm going to ride the snot out of it! I just got my Quebec season passes for my Wife and I and we are going to take a few trips and ride our sleds just the way they are. Too many engineers thinking too much. I'm thinking this has to do with the fact that we don't have any snow yet. Lets hope for lots of snow and riding and less wrenching.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Not sure I should of read this thread....my head is spinning. I think the only transfer I need is getting my sled from Ohio to the UP, that's the best transfer there is. I'm with a couple other guys on this, I went with the 137 for a quality ride, my days of racing thru the tight twisty's are over but, I still want to rail on the high speed technical curves though. I put a set of Curve skis on with Bergstrom 6" triple points and the next step is to dial in the balance for lighter steering effort. Dial in the rebound to my liking and I'm good to go.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I see these are from a 2014 post. STOCK in pic = stock spring in a 129 Viper = Stock spring in a 129 Winder. All 3 are lighter than the stock Winder 137 springs. I guess I missed the answer, did any of these accomplish what you wanted?Here.16+ spring is not shown in this pic. Goes from lighter to heavier. Cat #'s
Spring Chart
Stock 137 Winder spring is not in list
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
This isn't just about transfer. I needed 40 pounds in back to get suspension just to WORK. I like the ski's on the ground, but a spinning track does nothing.......except spin. If the front gets light, not OFF the ground, it means you are grabbing & going FORWARD.
I had last year to ride & was very happy in the end, but i knew exactly where i needed help for the "ultimate" ride.
I went with softer rear springs & studs. I'm hoping to just get front end light & bottom out on at least on one freakin' bump somewhere...
No thats why I said stock 16 spring is not listed. 16-18 all 129,137 Cats,Sidewinders and Vipers use same spring. I didnt have one at time pic was taken so its missing from the pic.I see these are from a 2014 post. STOCK in pic = stock spring in a 129 Viper = Stock spring in a 129 Winder. All 3 are lighter than the stock Winder 137 springs. I guess I missed the answer, did any of these accomplish what you wanted?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Couldn't Hygear tell you whether or not it was softer? I know their website is vague on that. It might be because its similar to the lighter of the factory springs.
Its interesting to go back and read the thread from last year.
Nobody posted about moving the scissor mount forward but some moved the coupler limit shaft back in the skid - 1 so much he added material to the top of the tab to hit the blocks.
Lighter factory springs or modding (shaving down) the coupler blocks is probably the best answer.
I forgot to call Hygear & will try tomorrow. I rode last year with aftermarket 4-way block adjuster that i believe is lower also.
As far as moving scissor, this needs to be tested. In theory it works, but reality is always different & poses other issues.
NEWTON's LAW states: For every action there is equal & opposite reaction.
P.S: I don't know if this saying fits this post, but it makes me sound real smart. lol
No none accomplished what I wanted but the current spring in Winder and Vipers was the best. Easily. Its what I have been running since 16.I see these are from a 2014 post. STOCK in pic = stock spring in a 129 Viper = Stock spring in a 129 Winder. All 3 are lighter than the stock Winder 137 springs. I guess I missed the answer, did any of these accomplish what you wanted?
actionjack
- Apr 9, 2005
The 129 Winder has the 1704-576 577 springs
Maybe I spent too much time reading this yesterday but
You have to cross the AC parts to the Yamaha parts
8JP-G7474-00-00 = the Cat 1704-576.7
8JX-G7474-00-00 = Cat 2704-026,7
Yamaha fiche part 2015 SRVIPER LTX DX
Part 40
Spring, Rear 2
8JP-G7474-00-00
Cat Fiche part 2015 SRVIPER LTX DX
Part 12
Spring, Suspension - Right - Black
1704-576
129 Winder has 8JP
137 Winder has 8JX
Yamaha fiche 2017 Sidewinder RTX
Part 39
Spring, Rear 2
8JP-G7474-00-00
Yamaha fiche 2017 Sidewinder LTX
40
Spring, Rear 2
8JX-G7474-00-00
Part 40
Spring, Rear 2
8JP-G7474-00-00
Part 12
1704-576
129 Winder has 8JP
137 Winder has 8JX
Part 39
Spring, Rear 2
8JP-G7474-00-00
40
Spring, Rear 2
8JX-G7474-00-00
I will bet thats a misprint. All Winders and Vipers along with the Cats have 2704-026,7 springs from 16+The 129 Winder has the 1704-576 577 springs
Part 40
Spring, Rear 2
8JP-G7474-00-00
Part 12
1704-576
129 Winder has 8JP
137 Winder has 8JX
Part 39
Spring, Rear 2
8JP-G7474-00-00
40
Spring, Rear 2
8JX-G7474-00-00
If not. There is a real good option for the 129" Winder guys!
actionjack
- Apr 9, 2005
Thanks for converting #'sThe 129 Winder has the 1704-576 577 springs
Part 40
Spring, Rear 2
8JP-G7474-00-00
Part 12
1704-576
129 Winder has 8JP
137 Winder has 8JX
Part 39
Spring, Rear 2
8JP-G7474-00-00
40
Spring, Rear 2
8JX-G7474-00-00
actionjack
- Apr 9, 2005
Now you've confused me. Isn't the point of this thread suggestive of a lighter spring for the 137 gets to get more sit in lighter skis when wanted? Also it seems if you are 200+ the LTX is probably perfect you but if you are smaller a lighter spring should help. Weird the 137 spring is cheaper. But 2 129 springs would be less than the Hygear price.If not. There is a real good option for the 129" Winder guys!
