ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
So Terry, would you be able to set them up to run the 1.5" wide Cat belts, or Ultimax 827(Cat size) and then would that work with our stock secondary?The clutch can be set up for any belt width, per request when purchasing.
Dan
- Apr 14, 2003
- Hessel, Michigan
Yes, the clutch can be set to any width belt.
If you order a clutch, whoever orders a clutch.... just needs to specify when ordering.
It will work with your secondary.
ktmhk53
Suspended
- Jul 4, 2006
These clutches have been out awhile for a lot of racers with very good luck
But I understand the "trail" version of this clutch is new. Definitely will outlast the competitors race clutch which they say is trail-able and has cracked after 500 miles
Why is a race clutch, which is designed to handle far higher HP than a trail clutch, more likely to crack?
Nickatnight987
- Sep 16, 2018
- Michigan
- 2018 sidewinder rtx se
Just seen this clutch at the novi show man was it hard to pass up, might be kicking myself for not buying it
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
Curious...who ELSE bought one??
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I’ll let you guys with the big money try it, let me know how it works after 1000 miles, then I’ll spend the money. I wonder what kind of warranty these clutches have for that price.Why is a race clutch, which is designed to handle far higher HP than a trail clutch, more likely to crack?
- Apr 14, 2003
- Hessel, Michigan
Keith, your clutch will be in my hands very soon. A lot of clutches were sold, including some 4 and 6 arm clutches.
These clutches are seriously jewels and have quality backing them up.
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
Lol! You guys are the one vendor I’m NEVER concerned about. I know it’ll be fine, and if it’s not, Im quite sure you’ll make it “right”!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
You betcha bud!
- Nov 29, 2009
- sabattus, maine
Does this use the same weights and springs as a stock primary? So if we already have a clutch setup we can swap everything over?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
The weights you can use your weights, or any weight that I have witnessed.
There was one guy who brought over some God awful 1" wide weight which I have never seen before. He was told he would have to mill his weights down to fit the Accelerator 3 clutch. The pocket where the weights go is .622" width.
As for a spring, I am glad you asked as this billet clutch will use a TRA spring. The reason is because the spider would have to be cut bigger diameter for the Yamaha spring.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Terry, so this will take dalton adjustables, same as many of us are running? Would they be similar range? 77g or so Im running now.The weights you can use your weights, or any weight that I have witnessed.
This would make the overall cost a bit more tolerable for sure.
Dan
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Dan
Yes, they will fit.
Any weight that is .622" wide or narrower
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
I want one. Are there any left from the first batch of 25?
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Any results on this clutch from those that have bought?
- 12K
