New Engine in 2016 Vipers and Other Changes
Picked up sled today, skis and engine new on Spring Power Surge.
Does it come stock with same clutching as last year? Track hp of 15 and 16?
Same clutching stock.
Stock (clutching & everything) 2014-2015 track hp = 72-73
Stock (clutching & everything) 2016 track hp = 75-76 consistantly
Thanks! Looking forward to your other tests of the new engine.
Just got word my snow checked LE just came in, does anyone else have one yet and if so what was you build date mine says 02/15
Seems a little weird to have s limited build sled built that early usually they are a late delivery. Anyone?
My sled is an 02/15. Old engine
Does this have the new motor?
No it does not have new engine. You can clearly see the old valve cover in pic of chaincase. They may have changed the dia in middle. In that case you would be able to check yours Joe. Will look at PDF and a sled with that shaft.
Just checked 8/15 build date.
The new driveshaft is nitride coated so it should be black. 14 and 15 weren't so should be easy visual check.
