BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
So are you saying the new engine is 140 /141 hp .2016 "new" motor seems to be 5-6 hp higher.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Most Vipers 2014-2015 I saw 128-130, new 2016 133-135.
Does it come stock with same clutching as last year? Track hp of 15 and 16?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Same clutching stock.
Stock (clutching & everything) 2014-2015 track hp = 72-73
Stock (clutching & everything) 2016 track hp = 75-76 consistantly
Thanks! Looking forward to your other tests of the new engine.
Does it hunt at idle?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
My sled is an 02/15. Old engineJust got word my snow checked LE just came in, does anyone else have one yet and if so what was you build date mine says 02/15
Seems a little weird to have s limited build sled built that early usually they are a late delivery. Anyone?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Does this have the new motor?View attachment 111178 View attachment 111177 Well some good news about my early build it has the new jack shaft and bearing in it and was a piece of cake to take out compared to the old ones. View attachment 111176
No it does not have new engine. You can clearly see the old valve cover in pic of chaincase. They may have changed the dia in middle. In that case you would be able to check yours Joe. Will look at PDF and a sled with that shaft.Does this have the new motor?
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Just checked 8/15 build date.
The new driveshaft is nitride coated so it should be black. 14 and 15 weren't so should be easy visual check.
New engine then I assume?Just checked 8/15 build date.
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Yes sir, engine and tuner 3's. Have to say for first Yamaha the fit/finish looks good.
You are going to really enjoy your new sled. Congratulations!Yes sir, engine and tuner 3's. Have to say for first Yamaha the fit/finish looks good.
