2008 Nytro RTX
Very nice,Any performance mods?
LJ 452
NLVMAX, is that the std. windshield bag? I got one as well, figured I'd put the foat pump in there. I just held it up to the opening and didn't think it would be close. Guess I should try again. Also, when they put your extro drivers on, how much did they trim the rail tips?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
An idea I have regarding the windshield bag is to somehow relocate the speedometer unit closer to the handlebars or maybe to the bars like the Phazers. This would free up a whole lot of space for a larger storage bag behind the windshield. What do y'all think?
NLVMAX
- Jan 18, 2008
LJ 452 said:NLVMAX, is that the std. windshield bag? I got one as well, figured I'd put the foat pump in there. I just held it up to the opening and didn't think it would be close. Guess I should try again. Also, when they put your extro drivers on, how much did they trim the rail tips?
Windshield Bag Part # SMA-8GL21-20-00
Pump will fit in there no problem. Regarding the drivers, tips were
not trimmed.
Oh by the way, I have the same wheels as you ordered.
Nice pics of your sled. Where did you get your skis?
Grimm, that is a good idea (relocate the speedometer closer to the handlebars) and I think some guys have done it. For me I might be rigging up something in that area for a GPS.
skyboz
I thought you were giving it to me!!! WTF???
LJ 452
skyboz said:LJ 452 said:NLVMAX, is that the std. windshield bag? I got one as well, figured I'd put the foat pump in there. I just held it up to the opening and didn't think it would be close. Guess I should try again. Also, when they put your extro drivers on, how much did they trim the rail tips?
I thought you were giving it to me!!! WTF???![]()
"Give" is a strong word, I told you I don't think it fits, but I guess it does. I'll have to revisit the install.
LJ 452
NLVMAX said:Regarding the drivers, rail tips were
not trimmed.
Oh by the way, I have the same wheels as you ordered.![]()
Skis were direct from Curves. Had USI's on the Apex last year, figured I'll give these a try this year.
Is there no concern with the rails contacting the tips? I thought trimming the tips had to be done? Anyone else have any idea? It's one of the main reasons I didn't go with extros right off the bat, figured I would wait and see if it's that bad.
NLVMAX
- Jan 18, 2008
Front protectors are removed.
08NitroRTX
couple things:
Yes you can use the Phazer speedo bracket but you'll have to splice into the extention wiring harness and lengthen it about 8 inches and drill a hole through your riser (pretty simple stuff) then your speedo is much easier to see and change when needed.
Also Be very carefull when tuning in those agressive skis. While they will corner much better than the stock skis they also will exagerate all incorrect adjustments! Take it ieasy until you have it dialed in!
Moved the speedo early in the season last year.
Little closer look.
lol nice face plant into the bars busting both my new Klim F4 and my wifes GPS! Speedo faired fine!
Moving the speedo freed up a lot of room infront of the bars!
Little closer look.
LJ 452
08NitroRTX said:Also Be very carefull when tuning in those agressive skis. While they will corner much better than the stock skis they also will exagerate all incorrect adjustments! Take it ieasy until you have it dialed in!
I plan on doing a TON of tunning this year. Hopefully the snow gods will be good to us in MI and I'll be able to have a track in the back 40. Get some good variety, studders, large 2-3 footers, it ended up looking like a snocross track last year, of coarse with out the jumps but the layout gave a good variety to get some adjustments made, then hopefully fine tune in the trails.
NLVMAX
- Jan 18, 2008
2008 Nytro RTX said:Very nice,Any performance mods?
Actually I consider the track and drivers a significant mod. Guys, with these drivers from Avid you can adjust your track so the tops of the rubber nubbins on the inside of your track are even with the bottom of the Hyfax. With your sled on a stand so the track is hung. I'm going to leave it for now until I get the track broke in a bit. When it loosens up abit.
Find out more about this perfomance mod here
http://www.avid-products.com/3inch_pitc ... rivers.htm
More to come!
NLVMAX
- Jan 18, 2008
ROX RISERS
Finished Installing my Rox Risers 7/8"x7/8". Got them from http://www.advdesigns.net/roxadhabarri.html I'm 6' and wanted the little extra height. This is a 15-20 minute procedure with no cable issues. If you experience any tension on the trottle cable, you can relieve that by cutting any cable ties stopping the cables from moving. Wasn't an issue here.
I'm pretty sure others have posted pics of this mod so I won't go into detail any more. Just a couple pics.
12mm socket and wrench with a 6mm hex and your laughin.
Cap will go on but it's stayin off on this one.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Can the stock plastic handlebar cap still be used with the Rox riser in place?
NLVMAX
- Jan 18, 2008
Grimm said:Can the stock plastic handlebar cap still be used with the Rox riser in place?
Yes it can. I had it on. I'm planning to mount a gps in that vicinity so I'm not puttin it back on.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
NLVMAX said:I'm planning to mount a gps in that vicinity so I'm not puttin it back on.
I've been planning the same thing. Where's the best price you're buying your GPS mount from? I'm looking at GPSCity.ca
- 25K
