LEE337
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
looking good! what are you planning for controls?
LEE337
Being that the boat is the size it is i am able to utilize stock yamaha control cables. I am also using the stock steering column, just modifying it a bit.looking good! what are you planning for controls?
LEE337
Dash
moab11
- Feb 4, 2010
- 2016 SKS 155
looking good!
What is the black box beside the tether cord? Also will this have neutral/reverse? or just forward only?
Gone Blue
- Oct 11, 2006
- Howell, Michigan
That thing looks killer!
G.B.
G.B.
FJR1300
Does your Father have his own machine shop?
Looking for someone to build PTO out put shaft for 1988 Yamaha TerraPro
LEE337
PM me
LEE337
looking good!
It is a jet drive so the impeller drives directly off the crank. So it is always moving forward if the engine is turning. The neutral/reverse will be handled by a reverse bucket over the jet nozzle.
The black box is a switch panel for the bilge pump.
LEE337
Not alot of pics from the weekend but made a lot of progress. Disasembled the whole boat, then flipped and installed the plastic on the bottom. Then i started reassembly.
LEE337
Got the coolant 90% complete last night.
LEE337
Had the boat running last night. Should be on the water this weekend!
I want to see some VID of it in action.Had the boat running last night. Should be on the water this weekend!
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Ya looks like it would be a blast !
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Wow just wow. I would be happy to figure out how to make mine go on the land in the summer much less the water! Jet boat conversion kit business coming soon haha
- 123K
- 6K
- 7K
- 28K
