Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
I installed the SB quiet clutch kit, see my front end rebuild thread for full write up. The little plastic shims solved the excess tolerance and resulting rattle problem. Only one season on them but they seem to work. I also did new rollers and a softer primary spring at same time.Has anyone made up a fix that gets rid of the clutch rattle for good? i am starting to hate my nytro just because of the rattleWould just love to start a new season without the noise
North Bay Ned 691
- Nov 29, 2016
- North Bay
- 2016 VK Pro II
Hello,I installed the SB quiet clutch kit, see my front end rebuild thread for full write up. The little plastic shims solved the excess tolerance and resulting rattle problem. Only one season on them but they seem to work. I also did new rollers and a softer primary spring at same time.
Where would I find the SB quiet clutch kit. I hate the noise on my 2016 VK.
Hooray!
- Aug 12, 2017
- Maine USA
You can find them at http://www.schmidtbrosmotorsports.com/quiet-clutch-shim-kit/, pic below of the "quiet clutch" kit. I also put the "comfort clutch kit" on mine with smaller diameter rollers and a lighter spring to lower the engagement down to 2800 rpm where we still have plenty of torque from our motors. I am running a stock secondary with no complaints, new belt and hit 104 mph on the optimometer last season with this setup (faster than I need to go!). Great products, see my signature for list of SB items I use. People comment they are expensive but I run a small business and understand that from start to finish in small batches time equals dollars, all have been a good value as I dont have time to try to source them or mess around fabricating them.
Pmtg04
- Jan 16, 2018
- Minnesota
- 2008 Nytro RTX
I used Yamaha primary spring p/n 90501-586J0-00 to lower my engagement. Way better.
I then snipped the rings off a few electrical ring terminals and installed them as shims to eliminate the rattle from the bolts.
So far so good.
So far so good.
Hooray!
- Aug 12, 2017
- Maine USA
Great idea!I used Yamaha primary spring p/n 90501-586J0-00 to lower my engagement. Way better.
So far so good.
Yamaha205
Anyone selling this kit in Canada?
Hooray!
- Aug 12, 2017
- Maine USA
All online sales so you can order I assume.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Pmtg04, pics please..
Pmtg04
- Jan 16, 2018
- Minnesota
- 2008 Nytro RTX
Mk1000
- Dec 13, 2015
- Private
- Yamaha
I tried the clutch shim kit and it didn't make a difference.
The noise comes from the stub shaft.
Hoping the modified stub shaft from Hurricane Performance will solve the issue (save your pennies though).
delong
- Aug 31, 2017
- dryden
- 2010 nytro mtx se 153
2003 xcr 800
While trying to quiet my Primary down like everyone else, i'm also looking at changing out the 16.5mm rollers to 14.5mm... does anyone have a set! Cost an arm and a leg by the time I get them up to canada! They dont have to be new!
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Look into the thunder products ones as the bushings in them actually last unlike the stock Yami ones.While trying to quiet my Primary down like everyone else, i'm also looking at changing out the 16.5mm rollers to 14.5mm... does anyone have a set! Cost an arm and a leg by the time I get them up to canada! They dont have to be new!
delong
- Aug 31, 2017
- dryden
2003 xcr 800
Thanks, I have looked, may have to go that route if someone doesn't have a set kicking around their garage....
Hooray!
- Aug 12, 2017
- Maine USA
Curious, the SB shim kit on mine works great, tightened things up a lot and now at idle does not sound like a diesel, yes still some noise but night and day IMO. Whose kit did you use? Maybe you had enough wear that the shims were not adequate too, I had a heck of a time getting them to fit on mine so already pretty tight.I tried the clutch shim kit and it didn't make a difference.
gutterboy2ca
All i did after installing the Factory yamaha Fly weight Rollers a,pins and washers to find it did absolutly nothing except break the Bank, i pulled the Bolt and Roller Pin from the Roller side, touched the Pin with my Grinding wheel and took just a fraction off the Pin.Reinstalled , and done the other 2, The bolt now sits Tight, don,t over tighten it as the Roller will not turn..My Noise is Pretty Much all gone now'
