Mountaintech
Is the access to the oil filter and drain plug adequate on the Viper chassis?
Yes they are not hard to get to through the inspection cover in the belly. You need to jack it up or put it on a lift to get under it. The drain plug on the oil tank is akward an you need to make a funnel out of a 1/2 gallon milk jug to get the oil to drain through the cut out in the running boards because it does not line up and can make a real mess.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Agreed. You NEED to have some sort of funnel to divert the drain oil
If i remember correctly,
I pulled the exhaust when i did my oil change because i had to adjust the chain.
Having the exhaust off gives you a fairly large access hole through to the bottom of the motor.
Mountaintech
Do you think the bellypan is stout enough to act as a skidplate?
No. It's not like nytro where a dent in it could be catastrophic but the pan will not take even a light hit without bending.Do you think the bellypan is stout enough to act as a skidplate?
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
No not at all.
There appears to be little to nothing for protection down there. Some very thin metal.
If you watch the second to last post/video yellowknife posted in his season long video thread. He has torn both sides open on the belly and does not remember hitting anything.
In my opinion a belly pan is a must do on this sled
You thinking about building a nice thick aluminum skid plate for us like you did on the nytro???
If so try to get it to cover the brake and chain case they appear susceptible to damage
Yes that little plastic cup under rotor got ripped off mine and I never felt or saw anything. Bent the edge pan is attached to on that side.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
The belly pan must be removed to change oil but I beleive it's a small price to pay. Also I think someone on the site was cutting a hole with a hole saw and putting in plugs to access the drain plugs. That could speed the oil change process significantly!
stingray719
I drilled a small hole to let melted snow out and found it worked fairly well for oil too....lol
Mountaintech
No not at all.
I'm looking into skid plate possibilities. Focusing on A arms and running boards right now.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Have you checked out the Viper Mountain Forum? I've not looked there but it seems like they might have what your looking for. Just checked, looks like your all over the mountain Viper Forum.I'm looking into skid plate possibilities. Focusing on A arms and running boards right now.
Mountaintech
Should have been more specific. I design and build the parts mentioned.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Well obviously you do LOL! My DUH!
SRX#756
- Jan 30, 2014
- Grand Rapids, MI
- 2025 SRX Sidewinder Final Edition #756 - 1.5" Ripsaw
2014 SRViper RTX SE - Yamaheaters HID Kit, Powder Pro Skis, SLP Can (Sold to brother)
2002 SXViper - Speedwerx Head, SLP pipes, Drag n Fly Heelclickers, Team Secondary Roller, Boyseen Reeds, 1.5 RipSaw, SRX torque limiter, 2" handlebar riser, rear heat exchanger (in heated storage)
- West Michigan
Anybody put a skid plate on their Viper? Is it easily removed to change the oil filter or do you have to drill and re-rivet it?
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
I did, it goes on with nuts and bolts.
