Grizz gusset saved my front end last season !
LM7800
Gusset kit is a no brainer. A C-clamp works very well to install bushings as well
Stone9
got the a arms and skis back on and I could not be happier with the turn out. the spindles are at the same angle for the first time since I bought the sled. Very tight also. Can't wait to test this bad boy.
Creek
- Apr 15, 2012
Hi!
Can somebody tell me outer diameters for -09 Nytro Oilite bushings, both lower and upper a-arms?
Planning to use them in a a-arm project, just need to know the diameters to be able to pick right tube dimensions.
Thanks!
Thanks!
1 TOUZAN
Something you mite want to try to make the bushings fit better is hone the A frame holes with a automotive brake wheel cylinder hone, I've done this on similar projects with success. I would think you could get it to a slight interference fit this way with out having to press them in hard. I'm thinkin if you have to press them in hard you're going to decrease the inside diameter a little and the suspension will be pretty tight until it gets broke in. Just a thought.
Beenba
Creek said:Hi!
Thanks!
If you had of asked me on Saturday I gladly could have mic'ed them for you. Too late!
I guess I could mic one of my old plastic ones if you think this will help, but it definitely will not be as accurate as the tube. LMK.
Creek
- Apr 15, 2012
Thanks for your offer, I think measuring the originals will help me out here!
Somebody told me that in -09 Nytro lower and upper arms do have the same diameter, which ought to be .9070". My sled is -08 so I cannot verify that myself, since in -08 Nytro the bushings aren't of the same diameter.
So, if they do match, I'll go ahead and use -09 bushings in my project. In -08 model the upper bushing is so tiny that gets broken very easily...
Thanks!
Thanks!
Beenba
You are correct. All 12 bushings are identical.
I quickly measured some and they came it at 0.910 +- 0.002 throughout the batch so your good. (they are likely 23mm bushings from igus)
- 7K
